Flush mounted glass
Author Topic: Flush mounted glass  (Read 4931 times)
Offline anlauto
Re: Flush mounted glass
« Reply #15 on: June 02, 2016 - 07:21:09 AM »
My brother-in-law and I were one of the first people to do this to a Cuda back in 1993. We welded filler pieces all around each window to fill the gaps then used the "T" shape trim from a Dodge Caravan.
Offline 70chall440
« Reply #16 on: June 02, 2016 - 10:48:51 AM »
Thanks Alan, unfortunately welding filler panels into the car is no longer an option. Several people have done it by using thick or stacks of Buytl tape and then using a T molding. Unfortunately, no one seems to be willing to explain exactly how thick or how much tape to use and what width of T molding works the best.
Current Mopar
Past Mopars
Offline Cudakiller70
« Reply #17 on: June 02, 2016 - 12:07:19 PM »
I know nothing of how to do this, but do have experience with butyl tapes, it might be better to use a hard shim to get and hold the window at the right height.  :dunno:  :2cents:
http://www.amazon.com/Plastic-Horseshoe-Shims-16-Blue/dp/B005NZSZ4U
The above is just my opinion
John Adams
Offline YellowThumper
  • I left the snow for this?
« Reply #18 on: June 02, 2016 - 01:43:38 PM »
Quote from Johns Cuda Shop build. Page 28
Re: 71 Cuda Pro-Touring Build
« Reply #407 on: September 15, 2015 - 02:53:11 PM »
Quote
Quote from: mrob on September 03, 2015 - 04:02:11 PM
Hey John, question about the front and rear glass. I noticed that you don't have the stainless steel trim. Did you just replace that with some sort of rubber seal? Just curious how you did that.
I flush mounted the AMD front and rear glass by stacking two 5/16 square buytl tape on top each other to get the depth and a 3/4 universal t molding glued in with super fast urethane ... :bigsmile:
Offline 70chall440
« Reply #19 on: June 02, 2016 - 05:55:12 PM »
Thanks.  :bigsmile:
Current Mopar
Past Mopars
