Author Topic: Pic request: lowered cars on leaf/torsion suspension  (Read 14993 times)
Offline dave73chally
« on: September 15, 2015 - 09:48:34 PM »
How low have you gone on a stock style suspension? I will be running the hotchkis tvs system and going to go as low as a I can, wondering what that is...post some pics!
73 Challenger
Offline CUDA JAS
  • vroooooom!
Re: Pic request: lowered cars on leaf/torsion suspension
« Reply #1 on: September 15, 2015 - 09:57:25 PM »
mine is running a little lower than stock...
74 'cuda 360/727
Just call me a gearhead!
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2 on: September 15, 2015 - 10:19:23 PM »
This Cuda had spacers and looked awesome!
« Reply #3 on: September 16, 2015 - 09:26:11 AM »
Both looking good. Any info on the wheel/tire setup on the red cuda with spacers?
73 Challenger
Offline dfrazz
« Reply #4 on: September 16, 2015 - 01:56:02 PM »
The wheels were 17s and 18s but I did not get any tire sizes.  Pure stock suspension up front, lowered by just the t-bars.
« Reply #5 on: September 16, 2015 - 02:58:48 PM »
Mine is turned down to a point  where the lower control arm pivot is level with the lower ball joint. This gives me about 2.5" of travel at the bump stop using a button style bump pad. Its hard to get a perspective on how low this is, but the top of the roof is about mid chest level.
« Last Edit: September 16, 2015 - 03:02:39 PM by HP2 »
Offline Mickm
« Reply #6 on: September 16, 2015 - 04:15:47 PM »
My 'Cuda sits on all stock suspension and lower to what you see here.
 It drives and rides great with no tire rubbing issues.
The wheels are 17"-F&R with 235/45-17's on the front and 255/45-17's on the rear.
Cheers!
Mickm
MickM
« Reply #7 on: September 16, 2015 - 08:07:21 PM »
with 15" rims...
with 18" rims...
« Last Edit: October 12, 2015 - 07:14:10 PM by brads70 »
Offline SBDave
« Reply #8 on: September 17, 2015 - 07:01:40 PM »
I would caution you against going too low. I did and the shocks were incorrect for the set up, they bottomed out first.  Make sure your suspension can cycle cleanly and double check your driveline angles.
Offline SBDave
« Reply #9 on: September 17, 2015 - 07:03:30 PM »
here's mine
« Reply #10 on: September 17, 2015 - 07:54:51 PM »
Great advice!  :2thumbs:
Offline Cudakiller70
« Reply #11 on: September 17, 2015 - 08:33:40 PM »
Those are Good points that should be checked and aware of. If I remember right someone correct me if I'm wrong, you can adapt early camaro shocks. They are shorter and by removing the bottom mounting tab will bolt right in. You may also need to cut down or buy shorter bump stops also. Attached video shows why driveline angle is important.
« Last Edit: September 17, 2015 - 08:35:49 PM by Cudakiller70 »
The above is just my opinion
John Adams
« Reply #12 on: September 17, 2015 - 09:05:53 PM »
What setup are you running at that height in your picture? Issues there? Looks mean
73 Challenger
Offline jordan
« Reply #13 on: September 17, 2015 - 09:48:04 PM »
18" wheels.  XV level 1 suspension kit.
« Last Edit: September 17, 2015 - 09:51:01 PM by jordan »
Offline Denison636
« Reply #14 on: September 17, 2015 - 09:55:29 PM »
Brads70 what kind of wheels are them? I like the look they have.
Its just a little 340 with a miss
