Do you have a stock oil pan? And issues running that low?? I also have a set of those headers...do you happen to run ta fast ratio arms??
Stock oil pan. I actually ran it around with the header flanges at 3.5" to the ground for awhile, but it got too annoying crawling over speed bumps at 2mph and a 45* angle all the time to keep from dragging the flanges. At a little less than 4" to the ground I almost never have any problems with speed bumps. Even at 3.5" to the flanges the only thing I ever dragged was the header flanges, I never had any issues with anything else dragging. I don't have the fast ratio steering arms, just the stock stuff.
Hotchkis TVS with 1.18 torsion bars almost as low as I can go. Need smaller or delete bumpstops. Those are 235/60 15s. I also run the fast ratio arms and with my 275/40 17 Falken 615s on the same rims 72blunblu runs, I have a slight rub at full lock from the back of the tire at the rear. I am sure a t/a box with the modified stops wouldn't rub.
I use Energy Suspension 9-9132G. They're .375" tall.
You can also use 9-9121G, they're the same round, button style as above but they're .687" tall.
My hotchkis UCA's came with 9-9118G, they're rectangular and .875" tall.
