Author Topic: Valve Cover Leak?  (Read 2027 times)
Offline Simple
Valve Cover Leak?
« on: September 16, 2015 - 05:47:01 PM »
Anyone have trouble with their valve cover gaskets leaking? I have tried the expensive blue "rubber" gaskets as well as the cork gaskets. Keep getting leaks in both sides. New fresh motor with new valve covers. Still leaks 😡
Offline 734406pk
  • Andy
Re: Valve Cover Leak?
« Reply #1 on: September 16, 2015 - 06:21:42 PM »
Do you have stamped steel or cast aluminum covers?
Offline tman
« Reply #2 on: September 16, 2015 - 07:11:53 PM »
Where exactly are they leaking?  at the lower corners?
Offline cudabob496
« Reply #3 on: September 16, 2015 - 07:46:09 PM »
search this site under "valve cover leakage" and there will be lots of info
2011 Kawasaki Z1000
Offline dougs bs23
« Reply #4 on: September 16, 2015 - 09:42:19 PM »
With the new gaskets get yourself a new set of bolts. The old ones may be stretched and not torquing properly
Offline YO7_A66
« Reply #5 on: September 16, 2015 - 09:58:41 PM »
 I had a leak on my stock steel 340 valve covers. I pulled them off to find that the bolts/washers had ripped the metal open around a couple of the mounting holes. After some J/B Weld, they are solid again. I also ordered the thick grey gaskets with the steel inserts. I applied some sealant to the valve cover side and torqued down the valve covers. I also bought the bolt set that has the WIDE washers. I have not had any more leaks.
Offline 734406pk
  • Andy
« Reply #6 on: September 16, 2015 - 10:29:55 PM »
Very common issue! Good fix! :2thumbs:
Offline Racer57
« Reply #7 on: September 16, 2015 - 11:30:19 PM »
Cast aluminum valve covers.......
Tried all types then bought the Moroso Perm-Align gaskets with the steel core. Since I have no plans or reason to ever take the covers off again I also used Black Permatex on both sides of the gaskets after wiping everything down with Prep-All. No leaks
Offline cudabob496
« Reply #8 on: September 17, 2015 - 01:29:38 AM »
and use new lockwashers under the bolt heads
2011 Kawasaki Z1000
Offline Racer57
« Reply #9 on: September 17, 2015 - 08:52:52 AM »
While their off, it would be a good idea to get a thread tap and clean the threads out.
