Author Topic: Upgrade radiator from 2-row to 3-row?  (Read 829 times)
Offline FCC
  • 1973 Dodge Challenger 340
« on: September 18, 2015 - 03:34:33 PM »
So I'm told my 26" radiator is plugged (for my 340).  I can either purchase a new one or re-core my existing using the top and bottom to maintain stock OEM look.  Would it be worth upgrading from the stock 2-row to 3-row?  I've read that upgrading to 3-row may not be that much more efficient as the to fit 3-rows, the tubes will be smaller translating to the surface area being smaller.
Any recommendations on what I should do?  Thanks in advance for any feedback.
Offline YellowThumper
  • I left the snow for this?
Re: Upgrade radiator from 2-row to 3-row?
« Reply #1 on: September 18, 2015 - 04:59:25 PM »
I would base answer on what type of driving you intend to do and also the average climate of where you are. If non spirited driving and/or cooler climate I would stick to stock.
Out here on the west coast we got heat, lots of traffic delays and of course the "spirited" driving.
I always increase the core number. Even if improvement is minimal it is still an improvement.
Don't forget a fan shroud.  They help immensely.
Offline FCC
« Reply #2 on: September 18, 2015 - 05:41:02 PM »
Thanks Mike.  I'm in Northern California so what you indicated is what I have...
"Out here on the west coast we got heat, lots of traffic delays and of course the "spirited" driving."
I am using the stock shroud.  Thanks.
Offline AARuFAST
  • AARuFAST
« Reply #3 on: September 18, 2015 - 10:11:20 PM »
Rad in our AAR plugged 2008.
Rad shop purchased new same size rad with 3 row. removed top, bottom tanks brackets swapped to new core.
275.oo.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
