Author Topic: Horn  (Read 618 times)
Offline cudabob496
Horn
« on: September 18, 2015 - 04:00:23 PM »
Got a Grant steering wheel with a button in the middle for the horn.
Just one wire coming up through steering column to horn buttom, which I assume
when you push the button, you complete a ground. Just one wire going up front
to horn. Is the front wire positive volts? Can't seem to make this work?
2011 Kawasaki Z1000
Offline roadman5312
Re: Horn
« Reply #1 on: September 18, 2015 - 04:04:35 PM »
Wire in sterring column grounds a relay, sends 12 volts to horn.
