Author Topic: 1970 340 power steering pump pictures  (Read 3316 times)
Offline brotow
  • There really is a Challenger in the backround
« on: September 19, 2015 - 12:12:46 PM »
I need a picture or two, or ten to see how my power steering pump should mount.  I have the triangle bracket installed on the water pump and two brackets on the pump,(front and rear).  I do not have a water pump that has the "extra  ear"  the front and rear pump brackets mount and would be the pivot point when adjusting the belt tension.  In all I have oly three brackets.
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline 1970A-66Challenger
Re: 1970 340 power steering pump pictures
« Reply #1 on: September 20, 2015 - 08:25:09 AM »
Hope this helps
Offline anlauto
« Reply #2 on: September 20, 2015 - 09:17:13 AM »
My 70 340 has a Federal pump....that is a Saginaw pump, which would be correct ?
Offline brotow
« Reply #3 on: September 20, 2015 - 01:07:30 PM »
AHA,     Just as I suspected, my brackets are for a different water pump.  I can use the brackets from my 74 chall 360 parts car, they appear to be the same as the front and rear brackets as in 1970a66challenger picture (thank you).  I media blasted them but they are pitted pretty bad. I'll have to paint them instead of powdercoating them. I am missing the small bracket that bolts it to the block.  I may just look for oes in better condition.    Thanks for the help.
Offline 1 Wild R/T
« Reply #4 on: September 20, 2015 - 02:28:25 PM »
70 vintage 340's used Federal not sure on other years..... Saginaw was used on 318 in 70....
