Author Topic: Dumb Aftermarket UCA Question  (Read 1761 times)
Offline anlauto
« on: September 20, 2015 - 09:49:54 PM »
Okay....These QA1 upper control arms manufactured for E Bodies appear to have polyurethane bushings.
Does the inside diameter of the socket allow for you to ditch those poly bushings and press in factory type rubber bushings ?
« Last Edit: September 20, 2015 - 09:52:19 PM by anlauto »
Re: Dumb Aftermarket UCA Question
« Reply #1 on: September 21, 2015 - 02:17:56 AM »
Dumb answer -
 I doubt the factory bushings would hold in there , the end is a tube , th factory arm only had approx 3/16 where it had the interference fit , the chances of the tube holding the bushing tight would be minimal
Offline 1 Wild R/T
« Reply #2 on: September 21, 2015 - 02:57:38 AM »
Dumb answer -
Not on a Mopar... They don't have the step like a GM.... Press fit the whole way in... But I agree it's doubtful they are the same diameter as OE Mopar bushings.... Might contact QA-1 & ask if they offer alternative bushings...
Offline TonyBolton
« Reply #3 on: September 21, 2015 - 06:45:00 AM »
Why would you want to replace the poly?
Offline anlauto
« Reply #4 on: September 21, 2015 - 07:32:17 AM »
They ride hard and tend to squeak  :2cents: and mixing poly with rubber is no good so if you use these uppers then you would need to replace ALL the rubber bushings in the car with Poly bushings.
« Reply #5 on: September 21, 2015 - 11:13:55 AM »
Agreed the bushing is not stepped  but the arn has a minimal contact area which is why they often had the support ring pressed on the other side
Offline blown motor
« Reply #6 on: September 21, 2015 - 12:48:42 PM »
Why can't you mix them?
Offline roadman5312
« Reply #7 on: September 21, 2015 - 12:57:25 PM »
                                       They have grease fittings.   :rebel:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: September 21, 2015 - 01:29:18 PM »
Might have to go another direction if you don't want poly's
