Author Topic: Center bore wheel question...  (Read 1968 times)
Offline Mpdlawdog
« on: September 21, 2015 - 08:06:06 AM »
What is the bore size that will fit a 72 challenger?  I found a set that has 75...anybody know what range will fit?
Re: Center bore wheel question...
« Reply #1 on: September 21, 2015 - 08:50:17 AM »
« Reply #2 on: September 21, 2015 - 11:15:09 AM »
Ford wheels are smaller diameter but I do not have the measurement handy
Offline Mpdlawdog
« Reply #3 on: September 21, 2015 - 11:16:21 AM »
Thanks...well yes and no...the rims I have on the car now are 72.6...is the 75 too much??
72.6 is what they measure on our cars according to the link...what does running a bigger bore do??
« Last Edit: September 21, 2015 - 11:19:05 AM by Mpdlawdog »
« Reply #4 on: September 21, 2015 - 11:25:32 AM »
it will put all the centering load of the wheel on the studs , I doubt it would cause a failure , or run untrue assuming you tighten the lugs evenly & use the correct lug nuts for the wheels
Offline Mpdlawdog
« Reply #5 on: September 21, 2015 - 11:36:43 AM »
Thanks...I don't want to make a $1600 mistake!
« Reply #6 on: September 21, 2015 - 12:11:35 PM »
you could have a small adapter ring made up to fit inside the rim , Brad could whip them up in an hour or so !!
Offline Mpdlawdog
« Reply #7 on: September 21, 2015 - 12:20:28 PM »
sounds like you and brad need to start a business! (hydroboost brackets and wheel bore adaptors)....Id already buy two things in your catalog!   I really like the wheels...20 lbs each!  Id feel more comfortable with them matching up "right"...
« Reply #8 on: September 21, 2015 - 02:05:18 PM »
