Author Topic: Trickflow Powerport 240 heads  (Read 12229 times)
Offline 734406pk
  • Andy
Re: Trickflow Powerport 240 heads
« Reply #30 on: November 01, 2015 - 02:27:27 PM »
Here are some pics:
Offline 734406pk
  • Andy
« Reply #31 on: November 01, 2015 - 02:30:02 PM »
The red tube shows the relocated oil feed passage for the rocker shaft. Sorry for the poor focus!!
Offline 734406pk
  • Andy
« Reply #32 on: November 01, 2015 - 02:31:37 PM »
Forgot a pic of the combustion chamber:
Offline 73440
« Reply #33 on: November 01, 2015 - 05:45:54 PM »
Lot more support for the rocker shaft.
Steel or titanium retainers?
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 734406pk
  • Andy
« Reply #34 on: November 01, 2015 - 08:17:37 PM »
Yes there is much more support for the rocker shafts. I'm using the chrome-molly 7 degree retainers for a flat tappet hydraulic cam. The plan is to use either a Lunati Voodoo 704 or a Comp Cam XL High Lift, in the low .500's and around 280 deg advertised duration. I want to retain the six pack set up so I don't want to over-cam. It is tempting though.... :grinyes:
« Reply #35 on: November 01, 2015 - 09:24:49 PM »
 :2thumbs:
Offline cudabob496
« Reply #36 on: November 02, 2015 - 04:10:22 AM »
So, at what point, would the TF heads be under-cammed?
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #37 on: November 13, 2015 - 09:12:02 PM »
Undercammed? I'm not sure what you mean. These Trick Flow heads outflow stock heads from .400" all the way to .600"  lift. This means that you can change your stock cylinder heads, use the same cam and see an improvement in power generally speaking of course...
Offline cudabob496
« Reply #38 on: November 14, 2015 - 02:48:31 AM »
only a 3 angle valve job??
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #39 on: November 18, 2015 - 10:48:49 PM »
That's correct! 3 standard angles for valve contact position and the rest is CNC'd! :2thumbs:
Offline cudabob496
« Reply #40 on: November 18, 2015 - 10:53:57 PM »
Guess I was under the impression that you could install higher flowing heads, but it was a waste of time if you
did not upgrade the cam as well?
2011 Kawasaki Z1000
Offline cudabob496
« Reply #41 on: November 18, 2015 - 10:55:48 PM »
Thought there was a significant benefit to go to something like a 7 angle valve job, that most performance heads had?
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #42 on: November 19, 2015 - 07:44:04 PM »
The 7 angle was used on "as cast" iron heads to blend the port for smoothing airflow etc. You can also "back-cut" the intake valve to take it to 9 angles I guess. Very labor intensive to say the least. These days with aluminum head castings and a CNC machine programmed to do the work, we get a superior product at a reasonable price.
It's not necessary to change the camshaft to gain horsepower with these heads but if you want take full advantage of the airflow potential, go for it! Just do your homework to match all components properly. Too much cam is not a good thing. :2thumbs:
