« Reply #40 on: November 18, 2015 - 10:53:57 PM »
Undercammed? I'm not sure what you mean. These Trick Flow heads outflow stock heads from .400" all the way to .600" lift. This means that you can change your stock cylinder heads, use the same cam and see an improvement in power generally speaking of course...
Guess I was under the impression that you could install higher flowing heads, but it was a waste of time if you
did not upgrade the cam as well?
Logged
2011 Kawasaki Z1000
