Author Topic: Ignition problems? Stick with factory or go aftermarket?  (Read 2952 times)
Offline Zack Mckellips
« on: September 22, 2015 - 04:08:34 PM »
So I have a basically stock 78 lil red express with few internal engine mods and a quick fuel carb , all factory wiring and Ignition system, only thing changed is the coil, it running like **** , all over the place , seems like an Ignition system issue to me , I have a full msd setup on my challenger,  works perfect love it , but do I spend 800+  to buy  that for the truck , or do I just start replacing the factory stuff that has probably seen better days , or go to a ready to run system, I see msd has them still pricey,  seen some cheap crappie on ebay for like $60 , sounds way to cheap , or are guys doing the hei thing ?  what are you guys doing when the factory stuff gets worn out ? Im figuring if I stick to factory,  either the distributor or the ecu box are probably were to start what is the most common  Ignition system part failure with older age?
Re: Ignition problems? Stick with factory or go aftermarket?
« Reply #1 on: September 22, 2015 - 07:07:46 PM »
Biggest problem I've seen is poor connections coming to the ignition system not delivering proper voltages causing starting/running problems
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #2 on: September 22, 2015 - 07:21:41 PM »
I did something similar to this
http://www.hotrod.com/how-to/engine/1311-convert-a-ford-or-chrysler-ignition-to-gm-hei/
If you do a google search you will find out its very easy and very affordable and works great , its been on my challenger for the past 2 years and no problems, I actually made a heat sink and mounted were the ballast use to be, and left the orignal ecu for looks but this way cuts out ballast and ecu and I love it  :2cents:
« Last Edit: September 22, 2015 - 07:23:26 PM by 72rtchallenger »
72rtchallenger
what happens in the garage
stays in the garage
Offline sassygreen
« Reply #3 on: September 22, 2015 - 08:24:17 PM »
you will never get your car to fire quicker than a msd ignition. If you want to hear your car crank and crank and crank by all means use the weak factory ignition.
« Reply #4 on: September 23, 2015 - 01:42:14 AM »
Well if everything is working 100 % I doubt you could make 1 more HP with an MSD , it could be as simple as a bad contact or pick pup coil or even the pick up coil gap which should be .008 which is one of the first things I would check
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #5 on: September 23, 2015 - 06:30:03 AM »
I'm hearing good things about Firecore.  Just ordered a new set up for my Charger.
« Reply #6 on: September 23, 2015 - 09:43:26 PM »
Thanks for the input guys , all good info , I have a few donor vehicles too , so I'll probably check the gap and wiring terminal s and go from there , I do like my msd setup on the challenger too , so I guess I have some options anyway , just was wondering what people were doing with there cars
« Reply #7 on: October 11, 2015 - 08:24:10 AM »
MSD for me. I noticed a distinct bottom end improvement, which is where most of the 'fun' driving is!   :burnout:
Also quicker starts.
I imagine any manufacturers multi spark design will do the job better than stock '70's era ignition.  :2cents:
I agree with CP though, high rpm peak horsepower is likely unchanged.
Offline rUNCHARGER
« Reply #8 on: October 12, 2015 - 12:11:34 PM »
I think the problem right now with factory stuff is getting a reliable ECU. 20 years ago it was a no brainer, just use a factory or MP ECU and stock distributor. Right now I like the availability and the performance of the MSD 6AL.
Because of my factory tachs I use MP chrome boxes in my cars but I have a new spare Chrome box/ballast in the glovebox of them as well. I haven't had any luck with aftermarket factory style ECU's either.
Sheldon
Offline solarguy
« Reply #9 on: October 12, 2015 - 12:26:12 PM »
I went with MSD on my 340 only because the ignition curve is sooo easy to dial in with the stop bushings,  (although I ended up needing the larger one from 4 seconds flat) using the msd distributor meant using the msd box, 6a in my case.  I believe there are stock type distributors that have easier adjustments for ignition curve available now though.  I happy but there are differnt options available than when I made the switch 10 years or so ago.
