Author Topic: How much metal should I expect in the first oil change of a newly built motor?  (Read 3543 times)
Offline Challenger_Chuck
I just did the first oil change in a newly built motor and I am curious what amount of metal should I find? So far I've found that the first quart of oil out of the drain plug had a distinct silver tinge. The bits were basically like metallic flake and seemed to stop as the oil continued to drain.  I have not taken apart the oil filter yet, but what should I expect inside it?
Thanks
sounds right , a small amount of the babbit bearings surface will be worn away leaving a silver metallic trace
Offline 1 Wild R/T
Not on any engine I've ever built.... Cut the filter... It shouldn't have much if any metal... If it does I'd be getting a look at the cam... :2cents:  I've seen a few engines with shiny oil.. I've also seen them eat camshafts.... I personally have never lost a camshaft but I sure worry about it & I'm very careful about starting a new engine...
Initial examination of the oil filter didn't find any metal. And I have yet to unfold each paper fold, so stay tuned.
Offline 734406pk
  • Andy
Hard to tell without looking at it, but it's a good idea to cut open the oil filter and inspect the element. Do you have a special oil filter cutter to do this? When inspecting the element, look for particles the size of flakes of pepper or larger. This will indicate a problem. Smaller pieces the size of say  "dust"  in a very small volume are usually seen the wearing in process. Change oil and use a quality filter, run the engine for say 250 to 500 miles. Then pull the filter and re-inspect the element. If its clean, your good to go!
I guess I just live in a different reality  :dunno: I have often seen a ultra fine silver metallic in the oil as rings wear in on the cross hatch & some babbit off cam brgs clearances .
 I have also been extremely carefully breaking in cams & doing everything perfectly & still lost 3 cams , that is a whole different reality , disassemble the engine clean everything , replace the oil pump cam & lifters & check every brg throughout the engine , there is no if when a cam wipes !
« Last Edit: September 24, 2015 - 10:00:37 PM by Chryco Psycho »
Offline 734406pk
  • Andy
 :iagree: did 3 filter inspections this week on rebuild engines looking for the same contamination. Drew oil samples on 2 Cummins QSC 550 hp diesels and 1 QSM11-670hp as well. They needed 500 hrs run in time plus 2 oil changes before an accurate oil sample can be taken due to high content of wear metals from break in. Some metal in the oil on a new or recon engine seems common from what I'm seeing. The level should decrease over time.
This has been my experience as well. The first oil change and filter inspection is nerve wracking!  :grinyes:
Offline turbo224
Magnetic oil pan drain plug. Get one. :)
~Tyler Larsen~Salt Lake City
-1971 Plymouth Cuda 440-6pk Tribute
-1992 Dodge Daytona IROC R/T
Offline 734406pk
  • Andy
Good idea! Someone makes a magnetic filter wrap as well if I'm not mistaken. You can even magnetize the dipstick! At least you will catch some iron particles. Everything helps!  :stirpot:
Close examination of the filter paper appears to be nothing more than dust size.  I have run her maybe 200miles since then and will change oil and filter before I put her away for the winter.  I most definitely will get a magnetic oil pan plug, and was unaware of the magnetizing of the dipstick trick.
Stay tuned and again... Thanks..
Maybe somone used never seize on some of the threads. Seen it a lot.  Some use it to tq down head, rod and main studs, instead of moly lube.   You just never can tell. Then sometines a machinist just doesnt get the block cleaned right after prep work.  Cam walk, drive pump, bronze bushing, the list goes on.
