Author Topic: 70s era disasymbled 440 engine worth?  (Read 2339 times)
Offline TonyBolton
« on: September 24, 2015 - 12:37:04 PM »
Have had this motor in my parents garage ever since I can remember riding my bicycle.... what would something like this be worth to somebody?
Any ballpark ideas are appreciated.
Offline HP_Cuda
  • Mopar or No Car!
Re: 70s era disasymbled 440 engine worth?
« Reply #1 on: September 24, 2015 - 12:40:58 PM »
Depends.
Is it an HP motor (otherwise known as a six pack motor), what kind of heads are on it. Has it been bored out to .60 over or sonic checked. What year and what it came out of might also increase the value. ???
B
Offline TonyBolton
« Reply #2 on: September 24, 2015 - 01:19:52 PM »
Highly doubt its a six pack motor.....just regular stock heads....stock....stock....and stock...
Offline anlauto
« Reply #3 on: September 24, 2015 - 01:22:11 PM »
What year is it ? Plays a huge difference in value :2cents: 1972+ not much
Offline TonyBolton
« Reply #4 on: September 24, 2015 - 04:11:58 PM »
Yea its prolly  75+....
« Reply #5 on: September 24, 2015 - 09:05:19 PM »
Well I doubt it has been rebuilt depending how old you are , probably just pulled out & left , I tend to think the other way , the early blocks were weaker & did not have the extra rib at head bolt depth so in my mind the later blocks are better some had steel cranks ,  not the heads though they got worse with 67 being the best . A quick look at the damper will tell , 1" thick is steel , thicker is cast which make zero difference if you are going to do a stroker build anyway , also a E stamped on the top pad indicates cast crank if it is cast after 71 .
has to worth $500 + in decent shape
Offline TonyBolton
« Reply #7 on: September 25, 2015 - 02:14:42 AM »
Good deal...thanks guys. I'll research those links.
Offline TonyBolton
« Reply #8 on: October 22, 2015 - 01:19:26 PM »
Looks like what I figured....
Offline crocha617
« Reply #9 on: October 22, 2015 - 02:53:37 PM »
Thats a decent date. Is there an HP stamp on the top pad?
Offline TonyBolton
« Reply #10 on: October 22, 2015 - 03:01:19 PM »
That's about all I got on....a lot a stuff still around it
