Author Topic: front disc conversion  (Read 912 times)
Offline mopar jack
« on: September 24, 2015 - 10:27:48 PM »
did the big rotor and pin type caliper conversion years ago and the brakes are much better than the 10 inch drums I had before. However I can't lock the front rotors on a hard stop with a 15/16 master cylinder. Will it help with a bigger bore cylinder?
Offline shawge
  • Zoiks!!
Re: front disc conversion
« Reply #1 on: September 24, 2015 - 11:02:55 PM »
With everything else being the same (caliper piston diameter, pedal ratio, rotor diameter, amount of pressure applied to pedal, and distance the pedal moved), a MC with a large bore size will have a lower MC pressure than a smaller bore size.
- Jerry
Offline 1 Wild R/T
« Reply #2 on: September 24, 2015 - 11:28:11 PM »
Translation larger bore makes less pressure so it requires a higher pedal effort.... You either need a smaller M/C bore or a booster....
Offline mopar jack
« Reply #3 on: September 24, 2015 - 11:50:13 PM »
I think a larger bore will make more pressure but take a more effort on the pedal to push it. I had a larger bore and the pedal was harder to push but  I could not lock the front rotors. The small bore I have now is very soft to apply but also travels further to the floor.
Offline shawge
  • Zoiks!!
« Reply #4 on: September 25, 2015 - 12:30:04 AM »
Did you have power drums before?  Is it power or manual now?  With a 15/16 bore, I assume it's a manual setup now  :dunno:
- Jerry
Offline mopar jack
« Reply #5 on: September 25, 2015 - 10:39:49 AM »
It's a manual set up. started as a 318 barracuda with 10 inch drums. Upgraded rotors to C body and stock pin calipers, installed a factory  proportioning/ metering valve and a rear adjustable prop valve. Car stops much better than stock but I can't lock the front rotors.
