Author Topic: Any probs with the MSD Ready to run distributor?  (Read 2768 times)
Offline DocMel
« on: September 30, 2015 - 12:30:00 PM »
MSD ready to run distro with MSD 2 coil on my 440:
Lately it seems that I have had a miss that has been getting worse, erratic of where it happens, etc.  Its so bad now it has a hard start, will barely idle, and almost shuts down when I hit the accel.  Runs rough
-Plugs I changed last night.  Same symptoms:  Replaced the MSD coil.  Same issue.
-Checked spark plug wires/boots.  Ok, no burns or arcing.
-Triple checked all wiring.
-Distro is snug at its base.  I did turn the distro base just a little either way to see if it had worked loose:  Makes symptoms worse
-All vacum lines are snug, no leaks or breaks
-Full 12v sitting still, 13.8-higher when engine is running
-Checked plugs. Most are wet w/fuel
I'm thinking the module inside the distributor is shot:  Loss or weak spark had got to be distro related
I'm not getting a flash on my timing light when attached, nor when plug is removed and grounded (checking for spark)  I have only checked number 1 this way, but at least 2-3 of the other plugs are wet w/fuel upon inspection
Any one have a simliar prob wth a MSD ready to run distro?
Offline 73_Cuda_4_Me
Re: Any probs with the MSD Ready to run distributor?
« Reply #1 on: September 30, 2015 - 12:45:26 PM »
Just for sh*ts and giggles... check the engine and battery ground straps to make sure they still have a good ground connections... bad grounding can induce all kinds of gremlins! If those are good, sounds like the module in dizzy...
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline Strawdawg
    • Vortex Buicks
« Reply #2 on: September 30, 2015 - 02:38:42 PM »
Also check the voltage at the distributor
Sent from my LG-H810 using Tapatalk
Offline DocMel
« Reply #3 on: September 30, 2015 - 05:23:21 PM »
Grounds/voltage are fine.   Re-sanded all grounds, it has gotten worse, as I just tried again: Now no run, but pops bad thru carb.   Has to be the distributor
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: September 30, 2015 - 05:24:07 PM »
Most likely the distrib unit.
Offline cudabob496
« Reply #5 on: September 30, 2015 - 05:36:54 PM »
replace the dist rotor?
2011 Kawasaki Z1000
Offline DocMel
« Reply #6 on: September 30, 2015 - 06:06:22 PM »
No need to. I did clean it up some just in case, as i did the inside of the cap
Offline cudabob496
« Reply #7 on: September 30, 2015 - 07:09:34 PM »
ok, but I've cleaned up a rotor and cap like you did, but still
a new rotor and cap ran much better.
Beats a whole new disributor.
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
« Reply #8 on: September 30, 2015 - 08:38:40 PM »
Assuming there are no cracks in the cap, it sounds as if the module is/has died
« Reply #9 on: September 30, 2015 - 10:07:21 PM »
I have had similar issues stranding the car 400 miles from home
Offline 734406pk
  • Andy
« Reply #10 on: September 30, 2015 - 10:19:45 PM »
Try taking the coil wire out of the distributor and hold it 1/4-3/8" away from say an intake manifold bolt. Have a friend crank the engine over. See if you have a a good healthy spark output from the coil while cranking, just be careful of course.
Offline cudabob496
« Reply #11 on: October 01, 2015 - 01:49:23 AM »
had a friend's 16 year old get crossway with a coil, and got shocked.
two days later he died of heart failure. Ground he was standing on may
have been wet.
2011 Kawasaki Z1000
Offline Fern
« Reply #12 on: October 01, 2015 - 06:42:25 AM »
Had a silimular problem. The coil tested well but ran rough. Changed the coil and problem solved. Not sure why it bench tested fine but would not run well in car.
Offline DocMel
« Reply #13 on: October 01, 2015 - 11:22:20 AM »
Yep:  Forgot to mention I did check the original coil by grounding.   And I got a new one, no improvement.   I have ordered a new module from Summit
Offline Denison636
« Reply #14 on: October 01, 2015 - 06:04:36 PM »
I just went with a msd and was going to bye the one you have and speed shop told me to stay away from them. They have had the same issues you are having with them.
Its just a little 340 with a miss
