Author Topic: truetrac noise, finally found it, not sure I can fix it!  (Read 21338 times)
Re: truetrac noise, finally found it, not sure I can fix it!
« Reply #15 on: October 04, 2015 - 10:51:36 PM »
They look good.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #16 on: October 05, 2015 - 03:17:32 AM »
Yep it's the truetrac.
Wow that sucks, sorry man.
Offline crash340
« Reply #17 on: October 05, 2015 - 05:42:58 AM »
I'm going to pull it this coming weekend, I have the original third member sitting in storage, its an open centre but for the short term I know its fine with no issues so I can stay cruising till its sorted and will give me a chance to inspect the side gears.
Greg
73 Cuda
Brisbane, Australia
« Reply #18 on: October 05, 2015 - 10:02:48 AM »
Wow not cool , how does the side gear move that much inside ?
Offline crash340
« Reply #19 on: October 05, 2015 - 04:08:50 PM »
Neil, that makes for a very good question
Greg
73 Cuda
Brisbane, Australia
Offline crash340
« Reply #20 on: October 12, 2015 - 04:40:13 PM »
Ok, pulled the center out over the weekend, here is a quick vid of the sidegear movement, it still has oil in it so once cleaned I should expect more movement, the oil is clean, no metalic fleck, the center has done 2000 miles behind a facotry low powered 73 340 with 90K Miles on it and a 727.
Greg
73 Cuda
Brisbane, Australia
« Reply #21 on: October 13, 2015 - 12:33:57 AM »
it can be fixed but at what cost ? I assume there is no warranty left ?
 You would think the side gears would be supported with a far stronger design , I bet Brad could machine it up with a stronger design .
Offline crash340
« Reply #22 on: October 13, 2015 - 08:07:33 AM »
Im sure Brad could, the bigger issue is my location  :aussie: to send it back freight alone is damn near the cost of another, I'm liaising with the good man Cass, hopefully he can help somehow, I purchased it it Jan last year and as indicated its only done 2000 miles and has been noisy since it went in, I have been chasing uni joints pipes, shocks all sorts of things rather than this as a last resort.
Greg
73 Cuda
Brisbane, Australia
« Reply #23 on: October 13, 2015 - 04:35:32 PM »
I understand all too well where you are located , I am in a similar situation here in Panama , I wonder how the design  could be strengthened
« Reply #24 on: October 13, 2015 - 05:42:46 PM »
I wonder if a custom bushing/spacer could be made to fix this, problem is you would have ta take it all apart to see if it's possible.  :eek4:
« Reply #25 on: October 13, 2015 - 06:20:07 PM »
Maybe a cup to hold the side gear in place . we need a damaged one to take apart & see what could be done to improve it .
Offline crash340
« Reply #26 on: October 27, 2015 - 01:18:43 AM »
Ok, update time.......
first and foremost a huge shout out has to go to our man Cass of Dr Diff. As most of you know Im down here on a little island. I had arranged for a shop owner out of WA to gather a pile of upgrade gear for me including an Eaton Trutrac so as I could pack it and ship it on my next visit there so as all items were pre placed effectively. He purchased the TruTrac from Cass. So two years later after a lot of back and forth between Cass and myself chasing this noise I finially discoved the issue and let Cass know. Cass could have told me to simply go back to the guy I bought it from and good luck but he didnt. Without any pressure I simply asked Cass could he ask Eaton what can be done on my behalf. To this end Cass did and advised after a couple of weeks that Eaton were sending a new replacement unit out and that I didnt have to ship the faulty unit back (freight at my end was going to be $200 to ship it back and so on). well that was last week, Im on holidays but my work mate just sent me a message that the new one has turned up for me at work allready.
NOW, THAT IS SERVICE!!!!!!!! Thanks Cass, Thanks heaps and also thanks to Eaton. :clapping: :clapping: :clapping:
Greg
73 Cuda
Brisbane, Australia
« Reply #27 on: October 27, 2015 - 05:51:26 AM »
Awesome ... this is why we deal with good people even if the cost is more , the service cannot be beaten .
 Thanks Cass !!
« Reply #28 on: October 27, 2015 - 07:11:49 AM »
 Thanks Cass !!
 :iagree:  Way to go DrDiff! :clapping: :2thumbs:
Offline 1 Wild R/T
« Reply #29 on: October 27, 2015 - 12:50:39 PM »
I glad Cass & Eaton stepped up & took care of you... But I'd like to know if there has been a design change to support the side gear for axial loading, or was there a isolated problem with your unit? It sounds like yours wasn't the only one.... Jousi reports having the same issue....
