truetrac noise, finally found it, not sure I can fix it!
Author Topic: truetrac noise, finally found it, not sure I can fix it!  (Read 21340 times)
Offline TelisSE440
Re: truetrac noise, finally found it, not sure I can fix it!
« Reply #45 on: January 17, 2016 - 07:43:59 AM »
As long as it's a clutch style, not a cone style... Cone style was junk when new & most are plain worn out....
I have the 489 case untouched until now. Didn't have a problem for two years but I would be less concerned if I had the clutch style one...
Offline Jousi
« Reply #46 on: January 17, 2016 - 08:09:39 AM »
Here is video of my Truetrac, don´t mind the dial, the car is shaking but the noise is just same when descending clutch pressed or neutral:
https://www.youtube.com/watch?v=D5_5L7Vp3VI
BH23G1B TX9 5.7 Hemi+5-speed
JH23J0B FC7 4-speed
BS23R0B TX9 auto
« Reply #47 on: January 17, 2016 - 11:36:38 AM »
its hit and miss I believe,
Hmmmm. I'm thinking I should rebuild the 489's I have myself. Any good places online or books to read to learn how to do it?
Not keen on spending 1400 bucks on hit or miss.
Offline crash340
« Reply #48 on: January 17, 2016 - 12:04:28 PM »
They are easy to do, just need a good torque wrench, the factory manual has the info you need, I'm sure if you don't have one someone can copy those pages for you, also get the crush sleeve elimination kit from Cass along with a rebuild kit and your gtg.
Greg
73 Cuda
Brisbane, Australia
