1971 REAL BS 'Cuda 383 not numbers matching but date coded 11-7-70 383 and matching 727 (to the motor) originally an A/C car it has been removed but comes with it. Very solid frame and floors. Trunk floor has scaled but is solid. Shows 64,000+ on the odometer and the car came from North Carolina in the early 90's. Originally equipped with power steering, brakes, front and rear sway bars, am-fm 3 speaker dash, ralley gauges (all work) ,a/c , tinted glass, 3 speed wipers.
THERE IS NO BUILD SHEET OR FENDER TAG. The car appears to be "What it is" IF documentation are important to you THIS IS NOT YOUR CAR.
I have replaced all 4 shocks, 4 new 15x7 Ralleys with B.F. Goodrich T/A radials, engine harness, forward lamp and rear tail lamp harnesses, new carb, distributor, plugs, wires, fuel pump, recored original 26" hd radiator, road lamps and brackets, speedometer cable,
I drove this car to the Mopar Nationals in August 406 mile round trip and averaged 16 mpg while traveling 70 mph. It runs and drives very well. It is NOT perfect and IS NOT a 70k car at half price. This IS a very solid, good car that is priced TO SELL.
I have found another car I want badly and need to sell ASAP!!! So here's the NO HAGGLE PRICE:$35K FIRM
1971 Cuda's don't come any nicer IN THIS PRICE RANGE. Look around most 71 Cuda's under $50k are project cars. You can drive this one home!!!
