Author Topic: K Frame Bolt Question  (Read 1952 times)
Offline daveh
« on: October 09, 2015 - 10:21:58 PM »
Hey Guys,
I just bought a new set of K Frame bolts and was wondering if when I install them I use red or blue Loctite or nothing at all.  What's the consensus?
Thanks
Offline HP_Cuda
  • Mopar or No Car!
Re: K Frame Bolt Question
« Reply #1 on: October 09, 2015 - 10:23:42 PM »
Since they go on at 150lbs of torque I wouldn't worry about it.
 :bigsmile:
Offline 1 Wild R/T
« Reply #2 on: October 10, 2015 - 11:08:20 AM »
I've never used loctite & I've never had one come loose...
Offline Katfish
  • 70 Challenger
« Reply #3 on: October 10, 2015 - 11:17:54 AM »
Put antiseize on them so they'll come out next time.
Offline daveh
« Reply #4 on: October 10, 2015 - 02:54:14 PM »
Thanks guys.
Offline roadman5312
« Reply #5 on: October 10, 2015 - 06:50:34 PM »
                              Yep    :iagree:   Because there's always a next time.   :smilielol:                :rebel:
« Reply #6 on: October 12, 2015 - 08:31:14 AM »
I use a lot of anti seize building these cars , cheap insurance when you need to remove them later especially the ones that go into the frame where the repair is tough once a bolt breaks off in there .
« Last Edit: October 12, 2015 - 10:33:34 AM by Chryco Psycho »
Offline moper
« Reply #7 on: October 12, 2015 - 10:15:29 AM »
I use a lot of anti seize building these cars cheap insurance when you need to remove them later especially the ones that go into the frame where the repair is tough once a bolt breaks off in there .
Yup. Anti-seize everything that doesn't get sealer...lol.
Offline daveh
« Reply #8 on: October 12, 2015 - 02:38:24 PM »
Cheap insurance thanks.
Offline cudabob496
« Reply #9 on: October 12, 2015 - 05:21:31 PM »
Anti-seize especially when bolting into softer aluminum.
2011 Kawasaki Z1000
Offline roadman5312
« Reply #10 on: October 12, 2015 - 05:46:18 PM »
Always antisieze stainless bolts to steel. I learned the hard way.   :misbehaving:
 :rebel:
« Reply #11 on: October 13, 2015 - 12:02:10 AM »
I generally avoid using SS bolts into iron , it never works out well
