When I bought my challenger it came with 3 rear ends. Two 8 3/4, one which is in the car, and a spare Dana 60.
The Dana 60 is from a truck, it had 8 lug drum brakes on it. I'm curious if it's worth running in my car. I know the obvious answer is yes, but this rear end appears to be offset and I don't believe it's a posi.
Based off the metal tag on the diff cover bolt it has 3.54 gears. Engine plans are a 512 stroker with a 4 speed A-833
Now I don't know much about rear ends (insert joke here) i mainly stick to engines so cut me some slack
Here are roughly the measurements. I already know I'd have to get it cut down to use it since it was from a truck with 8 lugs
IF i can use it i'll tear it down, get it blasted and get it cut where necessary.
Thanks!
