Author Topic: hydraulic clutch master  (Read 3374 times)
« on: October 12, 2015 - 11:29:05 PM »
there are 2 sources for these , one was Keisler that was not bleedable , what was the second company that was bleedable & bolted through the pushrod hole with a remote reservoir ?
Offline IroquoisPliskin
Re: hydraulic clutch master
« Reply #1 on: October 13, 2015 - 09:42:23 AM »
You mean master itself shall be bleedable? I have mine from American Powertrain but master itself is I think from wilwood and not bleedable. A remote aluminium reservoir available. The air can be removed from the system by opening slave bleeding screw and pumping master.
« Last Edit: October 13, 2015 - 09:44:51 AM by IroquoisPliskin »
(OO[ [ [ ] ] ]OO)
« Reply #2 on: October 13, 2015 - 10:10:40 AM »
do you have a picture of yours , I have the Mcleod slave & it is bleedable so yeah I don't need a bleedable master
« Reply #3 on: October 13, 2015 - 11:05:16 AM »
I just have went through my pictures but obviously there is no nice shot of it among them. The one below is not reaviling a lot. The other is showing the remote reservoir. Unfortunately I'm not at home currently so I cannot get you a nice shot any soon.
(OO[ [ [ ] ] ]OO)
Offline anlauto
« Reply #4 on: October 13, 2015 - 11:29:31 AM »
This Hydromax system came from American Powertrain, you can most likely get it from Summit.
It's a fully bleed-able system with a remote reservoir.
Offline anlauto
« Reply #5 on: October 13, 2015 - 11:31:24 AM »
Offline roadman5312
« Reply #6 on: October 13, 2015 - 11:37:58 AM »
                  Thats a nice setup but the firewall has to be modified. Thats what made the Keisler nice was it was offset to the left to hook to the clutch pedal.
« Reply #7 on: October 13, 2015 - 11:44:54 AM »
I have that kit installed and it works without modification to the firewall. However I drilled the clutch pedal to hook the rod in.
(OO[ [ [ ] ] ]OO)
Offline anlauto
« Reply #8 on: October 13, 2015 - 11:49:14 AM »
No firewall modifications needed. The four bolts around the push rod sandwich two mounting plates. The bolts can go through the large oval that's already there for the clutch rod. I did drill one, possibly two extra bolt holes to make it stronger I believe.
On the next car, I've already welded up the oval and plan on drilling new holes for a cleaner appearance.
« Reply #9 on: October 13, 2015 - 11:55:56 AM »
No firewall modifications needed. The four bolts around the push rod sandwich two mounting plates. The bolts can go through the large oval that's already there for the clutch rod...
Alan, as you seem to have built in more than one of these kits, can you tell me if it's necessary to change the slave cylinder when swapping from 23 spline to 18 spline? Or maybe it's same for both types of transmission?
(OO[ [ [ ] ] ]OO)
Offline anlauto
« Reply #10 on: October 13, 2015 - 12:07:15 PM »
Not a 100% certain, I've only dealt with 18 splines :dunno:
« Reply #11 on: October 13, 2015 - 05:50:51 PM »
Definatly different between 23 & 18 spline as the shaft & retainer diameter is much larger on the 18 spline , unless they use the larger retainer over the 23 spline ?
 I have the McLeod slave installed & working , I rigged up my own master & pedal system while it works it is not ideal so I njeed to upgrade to a factory pedal & better master so Hopefully I can buy the master alone .
Offline anlauto
« Reply #12 on: October 13, 2015 - 05:55:05 PM »
They do sell the same kit with out the slave cylinder :2cents:
« Reply #13 on: October 13, 2015 - 06:25:25 PM »
Cool , that will work
Offline DocMel
« Reply #14 on: October 13, 2015 - 08:34:33 PM »
My Kielser came with a in-line bleed fitting between the master cylinder and right before it goes into the bell housing
