Author Topic: VIN question  (Read 2614 times)
Offline blown motor
VIN question
« on: October 13, 2015 - 12:56:17 PM »
The thread by smash_beacham brought up a point about my car. Mine is a 74 with a rallye dash. The VIN starts JH23G4B. Does the JH indicate that it would have originally had a standard dash? I ask because rUNCHARGER stated that the 73 340 rallye dash would start with JS23
Offline anlauto
Re: VIN question
« Reply #1 on: October 13, 2015 - 01:31:07 PM »
The rally dash was standard in the JS cars, at least for 70-71 and I would assume for 72-74.
However the rally dash was optional in all JH cars as well.
No matter what your VIN is, your car could have a rally dash.
Offline EB3-GranCoupe
  • BP23 U0B
Re: VIN question
« Reply #2 on: October 13, 2015 - 01:56:02 PM »
The data plate on the inner left front fender will tell you whether or not your car came with a rallye dash gauge cluster.  Look for code A62 (and/or N85), if its there, your car was so equipped; if not, it was just a standard gauge cluster.
« Last Edit: October 13, 2015 - 01:58:34 PM by EB3-GranCoupe »
Offline blown motor
Re: VIN question
« Reply #3 on: October 13, 2015 - 04:48:55 PM »
Don't have a fender tag or broadcast sheet so I guess I'll never know for sure it it came with one. But I have it and that's cool  :thumbsup:
Offline rUNCHARGER
Re: VIN question
« Reply #4 on: October 13, 2015 - 07:55:52 PM »
Also I was wrong on the JS thing after 72!
Sheldon
Offline 70chall440
Re: VIN question
« Reply #5 on: October 23, 2015 - 01:24:47 PM »
You can perhaps tell by looking at the wiring harness and other dash components; the rallye instrument cluster used a different harness (wires for the tach, clock, etc). I have been told the light bar is different as well which I suspect has different placement of the lights than a standard dash. If someone did a complete swap, you will never know but most people wouldn't have swapped the harness. A standard harness is easily made to work with a rallye dash by running a few wires, so there wasn't much of an incentive to replace it with the rallye one.
I would assume that the heater control panel matched the rallye dash (assuming the car you have has a rallye instrument cluster in it now).
Current Mopar
Past Mopars
Offline JayBee
Re: VIN question
« Reply #6 on: October 23, 2015 - 02:29:04 PM »
My original standard harness had the clock wire because you could get the optional clock on a standard dash. All I had to add when I converted was the tach wire and an oil pressure wire. Standard harnesses had a bulb socket for oil pressure, that's an easy way to tell which was originally with the car.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline smash_beacham
Re: VIN question
« Reply #7 on: October 24, 2015 - 03:00:11 PM »
Good info shared by all! Thank you
Sent from my HTC One M9 using Tapatalk
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: VIN question
« Reply #8 on: October 25, 2015 - 11:12:27 AM »
I do believe that the rally light bar has 4 lights and the standard light bar has 3 lights.
I've personally changed half a dozen wiring harness's so if a mouse got in your car over the last 40 something years your harness could have been changed in a weekend's time. unfortunately you will probably never know for sure.  But you know for sure you have rally's now.   :2thumbs:
