Well, I have decided how to go about this. I will start out using my 727. Then later switch to the NAG1. Reason behind that is that I really wanna drive the car next summer, and the NAG1 swap will take more time and a lot of fabrication, if I start that now, my car will be in pieces for more that a year, possibly longer. I talked to Chris at Hotwire and it is possible to get the harness that I can use for the NAG1 and run my 727 with the same harness, I just have to use 2 different computers, and I can use the one I have for the NAG1. There will be $6-700 extra cost for another computer and 727 adapters etc, but it worth it to me. The big issue, headers for NAG1 and T-Bars is not solved yet. No one makes them. I will get the TTI's that fits the 727/T-Bars and hopefully I can modify the passengers side later to fit the NAG1 (with a right side starter), what I can tell the driver side header will fit from the 727, but I'm not 100% on that.
Btw, somehow I will find a way to shift the NAG1 with my stock shifter.
