Author Topic: AC lines for small block.  (Read 3143 times)
Offline carcrazyguy
« on: October 16, 2015 - 07:13:58 PM »
Trying to decide which would be the best and most cost efficient way to go.  I have the original lines for my AC system.   They are not in good shape though.  Does anyone make a complete set of new lines (already have the new compressor and receiver/drier)?   This is for a 73 Barracuda with a small block.
Offline roadman5312
Re: AC lines for small block.
« Reply #1 on: October 17, 2015 - 07:46:34 AM »
When you say your lines are not in good shape are you talking the rubber sections and or the metal sections. If the metal sections are good I can rebuild them for you.                              :rebel:
Offline carcrazyguy
« Reply #2 on: October 17, 2015 - 09:45:50 AM »
 I will get you pics of the lines.  Mainly just the rubber hoses are cracked from age.  Any ballpark idea on the cost to replace the hoses?
Offline roadman5312
« Reply #3 on: October 17, 2015 - 10:25:46 AM »
                    Post the pics so I can see what I'm dealing with. Are you going to use the original compressor ?
Offline carcrazyguy
« Reply #4 on: October 17, 2015 - 09:21:57 PM »
Yes I am using the original style compressor.
Offline roadman5312
« Reply #5 on: October 18, 2015 - 10:36:48 AM »
               I can rebuild them for $200.00 plus shipping both ways. That includes powder coating the metal tubes silver.   If you want to go with a Sanden compressor I have this setup for sale including the Bouchillon mount, Compressor, Belt, Hose Assemblys for $350.00 plus shipping. I built this for the Challenger, charged it it, turned it on once. Then we tore the car apart for the Hemi install.                   :rebel:
Offline carcrazyguy
« Reply #6 on: October 18, 2015 - 11:07:48 AM »
Do you have any close ups of a stock line rebuild that you have done?  I am trying to keep the factory look.
Offline roadman5312
« Reply #7 on: October 18, 2015 - 11:39:15 AM »
                  Nope, no pics. If your thinking about how the powder coat looks the lines in the picture above are powder coated.
Offline carcrazyguy
« Reply #8 on: October 18, 2015 - 02:02:21 PM »
Pm sent
Offline anlauto
« Reply #9 on: October 18, 2015 - 02:16:49 PM »
How do you un-crimp and re-crimp the original steel part of the lines ?
Offline roadman5312
« Reply #10 on: October 18, 2015 - 02:34:23 PM »
                             It's a secret.   :roflsmiley:     :rebel:
Offline 1 Wild R/T
« Reply #11 on: October 18, 2015 - 02:51:22 PM »
You cut it off... Then you silver solder on a new fitting which you crimp the new hose into.... There are a few tricks along the way, first getting a crimping tool that makes crimps similar to what Chrysler used in 1970... Second since all new hose has a vapor barrier to work with R134 the hose OD while similar is slightly larger than the original.... If your truly looking for OE you won't like it, most will never know or care....
Personally I wouldn't powder coat the lines, I've always had them plated in clear zinc.... It gives the OE silvery finish where you need it & the on the engine end you paint the parts black like OE....  When you have the lines plated it's done after crimping & the inside gets plated too assuring the inside is as clean as the outside.....
Offline carcrazyguy
« Reply #12 on: October 18, 2015 - 03:01:38 PM »
Is that the way that Classic Auto is doing their lines?  I know they are suppose to be the best place to send them.  However their price is not exactly affordable.
Offline 1 Wild R/T
« Reply #13 on: October 18, 2015 - 03:25:17 PM »
I haven't inspected theirs up close.... BTW the fittings I posted a picture of aren't the ones I use, there are much cleaner looking ones out there... But thats the picture I found....
