Author Topic: transmission control lever 727  (Read 693 times)
Offline tomsa
    • My cars in swedish
« on: October 17, 2015 - 03:19:26 PM »
Are there different lenght on the transmission control levers ?
I had a aftermarket shifter and changed that to a slapstick shifter now but the lower shifter arm collied withe the neutral/backup switch so it looks like if the lever would be longer it would solve the problem.
Can it be a other arm for the aftermarket shifter to fit their bracket for the wire ?
Re: transmission control lever 727
« Reply #1 on: October 17, 2015 - 11:42:03 PM »
Yes the slap stick uses a different throw lever
Offline tomsa
« Reply #2 on: October 18, 2015 - 04:13:55 AM »
Any part nr to look for ?
Is a a straight model or the offset model that's for slapsticks?
http://i.ebayimg.com/images/g/IqYAAOSw9mFWGNoZ/s-l500.jpg or
http://i.ebayimg.com/images/g/d4QAAOSwu4BV0J4R/s-l500.jpg
« Last Edit: October 18, 2015 - 07:34:09 AM by tomsa »
Offline Denison636
« Reply #3 on: October 18, 2015 - 05:33:23 PM »
If your still looking I have the T-Handle slap stick style I can ship. Everything is there down to the springs
Its just a little 340 with a miss
Offline tomsa
« Reply #4 on: October 18, 2015 - 05:53:48 PM »
I bought from Quapman but I have the wrong control lever but just found one so I hope thats the correct model
