Author Topic: Camshaft bearing  (Read 900 times)
Offline 7212Mopar
Camshaft bearing
« on: October 17, 2015 - 10:22:47 PM »
I pulled the camshaft today. Camshaft looks ok but the cam bearings are not in very good shape except the end bearing. Most likely never been changed. Is it possible to replace them with the engine still in the car? I see Summit sells the universal cam bearing tool and new bearings for a 340.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Re: Camshaft bearing
« Reply #1 on: October 17, 2015 - 11:38:34 PM »
yes it is possible but it rarely works out well as the brgs are generally tight & need to be sized so the cam turns freely
Offline mrjlr
« Reply #2 on: October 18, 2015 - 08:12:50 AM »
What method is used in sizing?
Like honing?
Jeff
Offline moper
« Reply #3 on: October 18, 2015 - 08:09:25 PM »
For all intents and purposes they cannot be done in the car. You could change them, but you'd have to pull the transmission to get the rear one out and replace the cam plug, and you've have to drop the crank to verify the correct placement. Plus you'd have no way to clearance them as Chryco said. You need to pul it and pull the crank (pistons can stay in the bores - just tie the rods out of the way...
Cam bearings are clearance by shaving with a bearing knife or utility knife blade. They should not be honed or shaped with any type of abrasive because the abrasive will embed in the bearing surface and tear things up when it's running.
Offline mrjlr
« Reply #4 on: October 18, 2015 - 09:06:20 PM »
Hmmmm...makes sense.   Thanks for the info!
 :cheers:
Offline 7212Mopar
« Reply #5 on: October 18, 2015 - 11:30:01 PM »
Thanks for the info. Looks like I have a much bigger job ahead.
