Author Topic: High oil pressure after oil/ filter change...cause?  (Read 5531 times)
Offline cudabob496
Re: High oil pressure after oil/ filter change...cause?
« Reply #15 on: October 23, 2015 - 10:20:36 PM »
I was actually reffering to the post higher up , but good to know the WIX has finer filtration
K&N has the finer filtration.
2011 Kawasaki Z1000
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #16 on: October 24, 2015 - 04:26:45 PM »
"10 microns K&N vs 19 microns Wix"
10 microns being smaller (1/2 the size) of 19 refers to the particulate size removal capability.
Being an HVAC guy I know the better the filter the more restrictive it will be with typically higher pressures also.
Appreciate all the input and will keep one eye on the gauge and one on the  :burnout:!
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
  • HvacMan
« Reply #17 on: October 24, 2015 - 04:28:52 PM »
Cuda bob...what brand synthetic are you running.
Does if have the zinc additive or?
Eric
Bay Area California
Offline 73440
« Reply #18 on: October 24, 2015 - 04:33:57 PM »
Off topic, run into this once in awhile, http://www.apartmenttherapy.com/terminology-turn-the-ac-down-o-123967
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline roadman5312
« Reply #19 on: October 24, 2015 - 04:44:19 PM »
               Interesting topic 73440. The art of communication can be a tricky subject, especially when getting to know someone new. Over the years I have run into situations where I ask someone to do something, they do it wrong and when I try to figure out why, sometimes it's in how I asked.   :rebel:
Communication is the key to success.    :rebel:
Offline cudabob496
« Reply #20 on: October 24, 2015 - 08:38:41 PM »
always used Mobil 1.  It has zinc, but not high levels of it. zinc only necessary on flat tappets, I thought?
2011 Kawasaki Z1000
Offline cudabob496
« Reply #21 on: October 24, 2015 - 08:40:09 PM »
I think the K&N uses a synthetic filter material that does not restrict flow, even though it filters at 10 microns.
2011 Kawasaki Z1000
