the same weight sythetic flows about twice as fast as the same weight dino.
Also lubricates better, and can stand up to about 700 degrees before breaking down, while
dino is about 450 I think. Engine will run cooler. Lotta wear is at startup, especially at the valve train, when you want the oil to flow quick.
Synthetic is just far superior, but that will be argued by some forever.
Give you an idea, I replaced my mechnical fuel pump rod after 15 years of full synthetic.
The about 4 inch rod only decreased in lenght 5/100 of an inch. If I had used dino, probably would have been a lot
more wear. I use full syn in engine, tranny, and rearend. Gives 20 more RWHP.
Also, last 10 years, rarely have to adjust valve lash on my solid roller. If I do, its just to snug it a little bit more.
