Brake drum help....
Author Topic: Brake drum help....  (Read 944 times)
Offline Mpdlawdog
Brake drum help....
« on: October 21, 2015 - 08:57:53 PM »
OK I sold my brake set up to a friend so I can buy Wilwoods...I have his drum brake set up to put on my car so I can put my wheels around so I can move it around…… Is there a left or a right? I can't find any markings on them any help would be great!
« Last Edit: October 21, 2015 - 09:01:38 PM by Mpdlawdog »
Offline Katfish
  • 70 Challenger
Re: Brake drum help....
« Reply #1 on: October 21, 2015 - 08:59:53 PM »
No L or R on the drums
Offline Mpdlawdog
« Reply #2 on: October 21, 2015 - 09:02:11 PM »
Sorry I was adding pics...so they are the same.....great thanks!!
Offline anlauto
« Reply #3 on: October 21, 2015 - 10:03:39 PM »
Lower ball joint will determine which side, either or is okay.
« Reply #4 on: October 22, 2015 - 11:43:00 AM »
the brake hose would point towards the rear but you are not hooking them up anyway
Offline jimynick
« Reply #5 on: October 22, 2015 - 09:44:44 PM »
The brake adjuster ports would be on the bottom as well.
Offline Moparparts
« Reply #6 on: October 25, 2015 - 11:27:33 PM »
I can't be sure in the pics but those almost look like pre 72 A-Body 10 in pieces and if they are right and left are different
Offline Mpdlawdog
« Reply #7 on: October 26, 2015 - 12:52:28 PM »
they came off my buddys 71 challenger convertible that he is restoring....The car sat in a barn for 20 years and  hasnt been driven i would assume since them....how can I tell???
Offline Moparparts
« Reply #8 on: October 26, 2015 - 08:33:59 PM »
If the bolt pattern is the same on both sides of the spindles(knuckles) they are E or B and will be the same for either side
