Author Topic: Mancini Racing Distributor  (Read 3138 times)
Offline DocMel
« on: October 22, 2015 - 10:45:01 AM »
Vacuum advance distributor (440) by Mancini at $139.00
http://www.manciniracing.com/ma413426440e2.html
 I checked Roseville, and an equivalent type is about $50 more
Is the Mancini worth it?
Re: Mancini Racing Distributor
« Reply #1 on: October 22, 2015 - 11:36:32 AM »
You want a dist with adjustable mechanical advance , I am not sue the Mancini one has that feature so ask about it before purchasing it  , Mancini used to list the one that is adjustable but I do not see it listed now . so maybe the Roseville one or the Firecore are better value for the extra $$
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2 on: October 22, 2015 - 11:58:18 AM »
Firecore has the adjustable mech advanced.  Mancini sells them, and the RTR version.  You can also order from Ron Wilson (Firecore Distributor) ron.wilson1@live.ca
I just dropped the RTR in my 440 '68 Charger and it makes a big difference!
http://www.manciniracing.com/maravaadeldi.html
« Reply #3 on: October 24, 2015 - 06:37:40 AM »
What differences from stock did you notice? Were you changing from a single/dual point to electronic?
Offline dfrazz
« Reply #4 on: October 24, 2015 - 07:53:06 AM »
I already had electronic.  But the entire performance of the 440 has improved in responsiveness, quicker start-up, idle is smooth, cruising, full throttle, and definitely stronger.
« Reply #5 on: October 24, 2015 - 11:05:49 AM »
Do you figure the stock unit was 'pretty used up'? Or in your opinion the build quality of the Firecore that much better.
I was contemplating the same replacement dist, but was trying to decide if it was an upgrade or not.
Offline dfrazz
« Reply #6 on: October 26, 2015 - 05:41:16 PM »
I think it is a combination of both.  The contacts and rotor still looked good on my old distributor, but the coil looked pretty old, so I think it was working o.k. but not as good as it could have been.  The Firecore is more advanced because it is newly developed.  I do think you will feel the difference, it won't be revolutionary but it will still be a noticeable improvement.  Also, the Firecore does have the brownish cap if you want to keep the stock look.
Offline solarguy
« Reply #7 on: October 27, 2015 - 03:01:29 PM »
how is the mechanical advance adjusted on the firecore?  I have a MSD that I run that uses easy peasy stop bushings.
Offline dfrazz
« Reply #8 on: October 27, 2015 - 03:13:30 PM »
Colored coded springs for stiffness that are included.  I got:
Billet RTR distributor $250
Firecore ignition wire set $115
Coil $45
Basically you get the whole system for what MSD wants for just the distributor....the MSD RTR is close to $400 and you still have to purchase a coil and wires.
Offline solarguy
« Reply #9 on: October 27, 2015 - 03:41:39 PM »
looks like a nice distributor.  The springs, I'm sure,  only effect how fast total mechanical timing comes on.  What adjusts the Limit of the mechanical advance?
Offline dfrazz
« Reply #10 on: October 27, 2015 - 04:25:45 PM »
You are able to slide and adjust plates inside the distributor, similar to the MP dist.
Offline solarguy
« Reply #11 on: October 27, 2015 - 07:52:43 PM »
 :2thumbs:
