Painting aluminum radiators?
Author Topic: Painting aluminum radiators?  (Read 3357 times)
Offline Road_Runner
« on: October 22, 2015 - 04:09:02 PM »
So has anyone here painted their aluminum radiator black to look more stock?  If so, what did you use and how well did it hold up, etc.?  I'm checking into getting a new radiator for the Roadrunner and wondering if there's a cheaper alternative to having one powder coated from the manufacturer.  Thanks in advance.
Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline Cudakiller70
Re: Painting aluminum radiators?
« Reply #1 on: October 22, 2015 - 04:11:16 PM »
 :popcorn: curious on this too
The above is just my opinion
John Adams
Offline cudabob496
« Reply #2 on: October 22, 2015 - 05:04:43 PM »
would think powder coating would hinder heat transfer
2011 Kawasaki Z1000
Offline cudabob496
2011 Kawasaki Z1000
« Reply #4 on: October 22, 2015 - 05:24:17 PM »
hey look what i found
http://www.eastwood.com/eastwood-radiator-black-paint.html
Standard engine paints are too thick for radiator use because they can interfere with heat transfer and block air flow between the cooling fins. Also, standard paint tends to flake off radiator tanks. Radiator Black helps solve this problem. Durable Enamel formulation resists temperatures up to 300ºF, gas and chipping. One can covers 6 square feet (most radiators require 2 cans). Net wt. 12 oz. Radiator Black Satin - Many have asked for a lower sheen radiator black. The lower satin sheen resembles the gloss level of modern plastic tank radiators and some imports.
Thanks cudabob496 for prompting me to go look, I can be my own worst enemy sometimes.  :eek4:
« Last Edit: October 22, 2015 - 05:33:48 PM by Cudakiller70 »
John Adams
Offline Road_Runner
« Reply #5 on: October 22, 2015 - 08:04:24 PM »
Read your link, so I wonder how different a light coat of radiator paint would be to a light powder coating?
Offline Road_Runner
« Reply #6 on: October 22, 2015 - 08:07:41 PM »
Bookmarked, thanks!
Offline jimynick
« Reply #7 on: October 22, 2015 - 09:17:25 PM »
One of my grandfathers had a rad shop when I was a kid and my job was to spray the rad when it came out of the tank and had been repaired- the paint was as thin as pee and it was only applied until you got coverage. The bonus, using paint, was that it helped protect the metal as well as make it look better and radiate better. I'd squirt-bottle some aluminum metal prep on, wash it off, blow it dry and use an aluminum friendly paint. Have fun.  :cheers:
« Reply #8 on: October 22, 2015 - 11:47:29 PM »
Good thinking, that would work too. Thanks  :)
John Adams
Offline 4Cruizn
  • HEMI FISH
« Reply #9 on: October 24, 2015 - 11:53:20 AM »
I have painted the front of the aluminum radiator in the hardtop as with a black car, it stuck out looking at the front.  I researched it prior and made sure I got the paint that was designed for radiators and it turned out good with no issues cooling.  Local auto parts store had the paint in stock and less than $10 bucks for a rattle can . . . .
 :2thumbs:
« Reply #10 on: October 24, 2015 - 04:23:36 PM »
Wonder if BBQ grille paint would work?    Oh no now I'm hungry.  ;)
John Adams
Offline Road_Runner
« Reply #11 on: October 24, 2015 - 10:00:36 PM »
Thanks for the advice, I think I've got a plan now!
Jim
Offline dakota
« Reply #12 on: October 25, 2015 - 09:53:39 AM »
I used the Eastwood radiator paint on my OEM radiator.  It took about 1.5 cans to cover.  The main challenge on application is spraying from lots of different angles.  It doesn't have much build, which is good.  The part has zero drive time on it so I can't speak to heat transfer of how it holds up to heat yet.
