Author Topic: 340-4 340-6  (Read 956 times)
Offline brotow
  • There really is a Challenger in the backround
340-4 340-6
« on: October 23, 2015 - 10:45:45 AM »
Does any one know the significance of the numbers 340 4 or 340 6 on the side of a 340 block?   had 2 340 blocks one had 340 4 on the side of the block the other had 340 6. What does the 4 and 6 represent?  4 barrel, 6 barrel?  Also the 340 6 block has a blank vin area, (replacement block?).
« Last Edit: October 23, 2015 - 12:44:36 PM by brotow »
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline ChallengerHK
Re: 340-4 340-6
« Reply #1 on: October 23, 2015 - 10:52:59 AM »
If it's what I think it is, this designates the casting run number, so the first was the fourth set of castings produced from a mold, and the second was from the sixth set.
- Han Solo, Star Wars
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: 340-4 340-6
« Reply #2 on: October 23, 2015 - 03:44:51 PM »
 :iagree:  Molding cast number.  Nothing to do with 4 or 6 barrel.
Offline Cuda Cody
  • Vancouver, WA
Re: 340-4 340-6
« Reply #3 on: October 23, 2015 - 06:51:16 PM »
Yes, as stated it's the casting number.  Every time they make a change or repair to the casting they change the number.  No VIN stamped is most likely an over the counter block.  If it's a warranty block it would have the rivet tag or at lest the hole.
