Author Topic: Speedo drive gear  (Read 1191 times)
Offline Those
Speedo drive gear
« on: October 23, 2015 - 09:02:46 PM »
I don't do much with automatic transmissions. I need to change the speedo drive gear on a 904 a wondered if the fluid drains out when the gear holder is removed like it does on a a833. Also any guess as to how many tooth gear I would need with a 904 and 3:23 differential with 225- 70 - 14 tires. Thanks to all replies.
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
Re: Speedo drive gear
« Reply #1 on: October 23, 2015 - 09:25:46 PM »
26.4" tall tire 3.23 rear gear = 33 tooth
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
« Reply #2 on: October 23, 2015 - 09:57:24 PM »
yes fluid will drain if you pull the drive unit out .
It helps to raise the rear of the car only so the fluid is more forward inside the trans .
