Author Topic: Vibration at 80 mph  (Read 3282 times)
Offline automate33
Vibration at 80 mph
« on: October 25, 2015 - 11:21:47 AM »
Hi guys,
i have dodge challenger RT 1971 340 with A904 and original drivetrain and i have vibration at 80 mph
Tires and geometry of the car was controled, but always vibration at 80 mph.
Is it possible that this vibration comes on the yoke?
What do you think?
thanks!
Offline GoodysGotaCuda
Re: Vibration at 80 mph
« Reply #1 on: October 25, 2015 - 11:24:45 AM »
What do you mean by the tires and geometry of the car were controlled?
Certainly the driveshaft is the first thing to look at. Old joints, out of balance, improper pinion angle. Then there is also the rear axle and transmission outputshaft that can contribute as well.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline sadil340
« Reply #2 on: October 25, 2015 - 12:11:22 PM »
Will be following this thread!
Been chasing a phantom vibration for 30 years. Engine/trans/rear end rebuilt, new clutch throwout bearing pilot bushing u-joints and front yoke. Axle/driveshaft trueness and pinion angle checked. Still there.
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
Offline Racer57
« Reply #3 on: October 25, 2015 - 10:10:42 PM »
I have a similar problem and I'm starting to wonder if maybe the rear brake drums (front disk) might be out of balance. They appear to probably be the originals or at least that old and with dents on edges from being dropped, rust and brake surface being machined kind of makes me wonder. New costs about $35 each so when I get around to it I'm getting new.
« Last Edit: October 25, 2015 - 10:12:39 PM by Racer57 »
« Reply #4 on: October 25, 2015 - 10:19:26 PM »
are the ires round ? seriously , BFG usually are not !
 Check U joints , rear trans bushing
« Reply #5 on: October 25, 2015 - 10:19:59 PM »
It could be driveline angle too check the video above
Offline automate33
« Reply #6 on: October 26, 2015 - 03:21:05 AM »
I will controle driveline angle, My challenger rear raise some
Offline RusTy/SE
  • Just havin' fun
« Reply #7 on: October 26, 2015 - 07:28:46 AM »
Try this..
Next time you're approaching 80mph, slip the trans into neutral. If the vibration continues, look to the suspension. If the vibration stops, look to the drivetrain.
I may have that reversed - can someone verify?
I'm curious though. You mention original drivetrain - didn't all 71 340 motors get backed up by the 727-A rather than the 904?
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline automate33
« Reply #8 on: October 26, 2015 - 07:35:44 AM »
Thanks for tips!
Exactly, my original drivetrain was 727 but he was changed in 76' following a problem.
I will try your tips this week end!
Thanks
Offline RusTy/SE
  • Just havin' fun
« Reply #9 on: October 26, 2015 - 07:49:29 AM »
Cool, others with a much better working knowledge than I have will likely chime in to further pin down the cause.
 :cheers:
Russ
2001 Durango     1B4HS
Offline sadil340
« Reply #10 on: October 26, 2015 - 08:00:36 AM »
Try this..
You have it right.
The strange thing about my vibration? If I approach 70 or 80 and push in the clutch then release it quickly the vibration goes away. It's like something self centers during that process.
3:55 SureGrip
Owned since 1974
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: October 26, 2015 - 01:57:08 PM »
I'd pull the driveshaft and take it down to a shop that can run it up and see if there is any balance issues.
If so, you can correct them right then and there. Unfortunately it's a process of elimination so if you want to start from the cheapest and go to the most expensive that is also another way to go.
Offline automate33
« Reply #12 on: October 26, 2015 - 02:41:05 PM »
I have to control with a laser. if I put the laser flush the underbody, rear, I have compared to the prior 4 cm difference. is this normal? I think this should be level. no?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #13 on: October 26, 2015 - 02:56:42 PM »
Sometimes seeing imperfections in the driveline require putting it on a machine and measuring how far out of balance is necessary.
You can try all the cheap items first like: u-joints, wheels, tires, etc...
« Reply #14 on: October 26, 2015 - 03:02:35 PM »
I eliminated most of my vibration issues by raising the rear and running the car in first gear. Need two people to be safe!
By doing this I found one wheel was slightly wobbling. I took that wheel off and found the axle flange had been tweaked. Replaced the axle and solved the majority of my vibe issues.
Still not perfect, but a lot better than it was.
