Author Topic: Hotchkis Sub-Connector Install Question  (Read 2665 times)
Offline FY1Cuda
« on: October 30, 2015 - 04:44:00 PM »
My son bought the Hotchkis sub-frame connector kit for his '70 Challenger.  This is the one that has a bracket welded on the cross-member in front and the rear of the connector bolts up to the leaf spring shackle.   I read their installation instructions, but the question I have is about how to route the E-brake cable.  This is the '70 style of e-brake with the single cable going back to a little in front of the rear axle where it splits to each of the rear brakes.  When the connector is in place , the cable is outboard of it in front and inboard of it in the rear.  Does the cable just ride over the sub-frame connector?
http://www.hotchkis.net/product/1970-1974-dodge-challenger-subframe-connectors-from-hotchkis-sport-suspension/?mk=40&yr=1970&md=286&sm=295
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Hotchkis Sub-Connector Install Question
« Reply #1 on: October 30, 2015 - 05:11:18 PM »
The Hotchkis subframe connector sits low and does not come in contact with the floor pan.  The e-brake cable sits between the floorpan and the connector.  There is no reason to drill a hole in the connector for the cable, as is required by other connectors that match up to the floor pan.
Offline roadman5312
« Reply #2 on: October 30, 2015 - 05:28:43 PM »
                            :iagree:  Yep we installed them no prob on the cable.      :2thumbs:                   :rebel:
Offline dfrazz
« Reply #3 on: October 30, 2015 - 06:00:40 PM »
Scale of 1-10, how much of a difference did they make?
Offline roadman5312
« Reply #4 on: October 30, 2015 - 06:18:05 PM »
                Honestly I never drove the car before I installed them. Toxic did but he never drove it after they were installed, long story  :roflsmiley:  I did drive her after I installed them, but I also installed the entire package with UCA's, sway bars, the works. Handeled incredible, even with the stock torsion bars. I highly recommend.       :rebel:
Offline dfrazz
« Reply #5 on: October 30, 2015 - 06:20:16 PM »
Sweet!
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: October 30, 2015 - 06:22:49 PM »
I have subframe connectors in and the cable has plenty of room to go between the floorpan and the connector.
 :2thumbs:
Offline Mpdlawdog
« Reply #7 on: October 30, 2015 - 07:07:44 PM »
Any pics or tips on the install?  I have a set on the shelf waiting for me to get off my butt and get back working on the car!!!
« Last Edit: October 31, 2015 - 09:21:56 AM by Mpdlawdog »
Offline FY1Cuda
« Reply #8 on: October 30, 2015 - 08:08:38 PM »
Any pics or tips on the install????
There are instructions on the website.
Thanks for all the quick responses.  I waited for over twenty minutes to ask tech support at Hotchkis and got cut off, so I appreciate all the knowledge.
Offline soundcontrol
« Reply #9 on: October 30, 2015 - 08:14:12 PM »
8 to 9 for me. Convertible, it stopped all my rattles, the top frame was shaking and squeaking all the time before, and the car felt sturdy as a tank afterwards. This was the US Car tool version, but I guess Hotchkis are similar.
« Last Edit: October 30, 2015 - 08:16:09 PM by soundcontrol »
/ Ken
topic=108917.new#new
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: October 31, 2015 - 01:48:44 PM »
Here is a tip that I had to learn because the guy I got one of my cars from did it wrong.
Do not weld the subframe connectors so close to the floor pans they touch.  :bricks1:
Pissed me off so bad when I found out.
