Author Topic: help with wheel seals  (Read 971 times)
Offline hato
« on: November 02, 2015 - 04:53:33 PM »
so yea another hiccup  the seals i got dont work i need ones for a 1.73 inside diameter  and 2.6  outside diameter the local parts jockeys cant help and tired of running into problems thanks in advance for any help  :D
70 FY1 challenger rt/se  440 U code 727 matching numbers power everything rear defogger
70 ff4  gator grain top t/a
Offline 1 Wild R/T
Re: help with wheel seals
« Reply #1 on: November 02, 2015 - 05:48:20 PM »
What spindle & rotor are you using?  Never mnd,  1.73 is the typical 70-71 spindle & 2.622 is a 73 & up rotor....
I think your best bet is a National 472185   The OD & width are good, the ID is .020 O/S but since the typical seal lip deflection is .060.. & your sealing grease not a fluid it should be fine...
Offline hato
« Reply #2 on: November 02, 2015 - 06:20:37 PM »
 :wow:I was just in the garage mocking it up it looks like I might need the 73 spindle I can order those though dr diff right?  I should mention the rotors and seals are from him as well
Offline 1 Wild R/T
« Reply #3 on: November 02, 2015 - 06:40:37 PM »
Why do you need the 73 spindle?  It'll bolt right on so it's a good upgrade but I'm guessing you got the rotors & the bearing spacers from Dr Diff?
Offline hato
« Reply #4 on: November 02, 2015 - 07:05:57 PM »
I did get the rotors and bearing spacers from him few places wanted crazy money for rotors lol
Offline 1 Wild R/T
« Reply #5 on: November 02, 2015 - 08:02:11 PM »
So use your spindle, the spacers, bearings & rotors you got from Cass & a pair of National 472185 seals.. You should be good to go..
Offline hato
« Reply #6 on: November 02, 2015 - 09:12:28 PM »
Awesome this boards the best thanks for the help gonna pick em up in the morning and finally can finish the t/a suspension. If I get another setback am just storing it till summer lol
