Author Topic: 383 electronic distributor  (Read 1862 times)
Offline moparnut
    • My Photo's
« on: November 03, 2015 - 10:51:08 AM »
Its been a while, does anyone know the part number for a factory electronic distributor for a bb 383? I am not talking pertronix or moper perf but OEM
thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline 4406v
Re: 383 electronic distributor
« Reply #1 on: November 03, 2015 - 12:42:25 PM »
I'm not sure but factory electronic ignition was not standard until 1973 by that time the 383 was long gone replaced by the 400? The experts may know but I'm pretty sure you're going to have to get a Mopar Performance unit or stick with a points type?
"Live for today, Tomorrow never comes"
Offline MOPAR FANATIC
« Reply #2 on: November 03, 2015 - 12:58:37 PM »
 :iagree: 4406V I believe your right on the money with your reply.  :bigshades:
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
« Reply #3 on: November 03, 2015 - 12:59:37 PM »
Correct last year for the 383 was 71 Electronic became optional in 72
Offline 4406v
« Reply #4 on: November 03, 2015 - 01:14:34 PM »
My suggestion would be to do like I did with my 71 Cuda when converting to electronic ignition. I bought a conversion kit which included everything (distributor,ecu,ballast,and wiring) I bought a harness for electronic ignition from Bill Evans (Evans Wiring) and then the bracket from Rocket Restorations that mounts the ECU to the back of the valley pan behind the intake. Converting back to original points type is a simple bolt-on and you haven't drilled any holes in your firewall. This also hides the fact that your car isn't "stock".
Offline ShelbyDogg
« Reply #5 on: November 04, 2015 - 02:26:09 PM »
You can use your points distributor and convert it to electronic by taking the felt pad out, then the clip, sliding the cam off, then swapping all of the parts out of an electronic distributor. I think I just made the hole a little bigger where the wires come out.
Offline BFM_Cuda
« Reply #6 on: December 05, 2015 - 11:52:53 PM »
Thanks ShelbyDogg; just the info I was looking for.   :thumbsup:
Offline ShelbyDogg
« Reply #7 on: December 06, 2015 - 01:28:18 AM »
You're welcome!
