Author Topic: Gas Pump Recommendation Needed  (Read 1193 times)
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
« on: November 07, 2015 - 09:22:39 AM »
I have a leaking gas pump that is making a mess of my garage.
What is everyone running for a stock manual pump set up with a late 60's 440 4-BBL with a mild cam.  It's a cruiser.
Is there a stock option that works well?   Or best to go aftermarket (Holley, etc ....).
Thanks everyone ........ CHAPS!
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
Offline anlauto
Re: Gas Pump Recommendation Needed
« Reply #1 on: November 07, 2015 - 09:28:53 AM »
I run Carter M4845 on all my stock 440 rebuilds. In fact I just ordered this one last night http://www.summitracing.com/dom/parts/crt-m4845/overview/make/dodge
You should be able to get then local at NAPA or CarQuest
Might condider a new fuel pump push rod while you're at it too :2cents:
Offline 73440
« Reply #2 on: November 07, 2015 - 09:32:25 AM »
I had a Carter 1994 on my '68 440, replaced with a Carter 4845 but original fuel line is wrong fitting for the 4845,
I had to end up using AN fittings and hose to run from fuel pump to Carter carb.
Bought from Summit, just have to watch inlet and outlet fitting sizes.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline anlauto
« Reply #3 on: November 07, 2015 - 11:08:59 AM »
There's an adaptor you can buy to get the factory line to fit, line requires a little tweaking... :2cents:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #4 on: November 07, 2015 - 11:44:40 PM »
I ordered the high flow pump from 440 Source and have had no issues.  I also replaced the rod, and would highly recommend you do too!
http://store.440source.com/High-Volume-Mechanical-Fuel-Pump/productinfo/138-1013/
Offline 73440
« Reply #5 on: November 08, 2015 - 12:36:17 AM »
I had to get some new tools and got to make up the line and fittings , so new tools and learning some thing is OK.
Took three or four tries to get the fitting on , but ended up using a hose clamp to help get the hose into the fitting.
Used the DEI insulation on the fuel line.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #6 on: November 08, 2015 - 01:37:03 AM »
watch the inlet port on the HV  pumps that can be disassembled , most is have seen have only a 1/4 " hole in the pump housing as cast & need to be opened up or they will be restrictive
« Last Edit: November 08, 2015 - 01:39:32 AM by Chryco Psycho »
Offline chaps70rt
« Reply #7 on: November 08, 2015 - 06:47:36 AM »
Thanks for your responses.    YES .... I already changed out the fuel push rod.  My engine sat for many years on an engine stand due to this exact issue not diagnosed.    Not sure if these were normally swapped out when the fuel pump failed, but it probably should be.
Cheers .... :cheers:
Gary
440 - 4BBL - Shaker
