Author Topic: Melted ignition switch dash plug  (Read 742 times)
Offline 71340RT
« on: November 09, 2015 - 12:14:49 AM »
I drove my challenger last week and noticed my dash gages all went to the lower end and my amp gauge was at the high end. I went straight home and noticed a smell of burnt wires. Here is the plug that I found has burnt on both ends so the wiring harness will be changed out and the ignition switch as it has melted to. Hope is all goes smooth and I have another wiring harness already to go soon as I find time to pull it all apart. Take a look at my plugs that got hot and melted.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Re: Melted ignition switch dash plug
« Reply #1 on: November 09, 2015 - 05:36:14 AM »
The large red wire barrel connector overheating and melting is not a rare occurrence.
Glad you made it home. Also a little surprised you managed to get home with that. Voltage to the coil must have been getting pretty low!
Offline roadman5312
« Reply #2 on: November 09, 2015 - 06:24:01 AM »
This would be a good time to bypass the amp gauge and comvert to to volts.   :rebel:
Offline YellowThumper
  • I left the snow for this?
« Reply #3 on: November 11, 2015 - 04:45:41 PM »
This would be a good time to bypass the amp gauge and convert to to volts.   :rebel:
X2 on that. Also check out your firewall bulkhead connections on the engine side. Put odds down you have more. Unfortunately this is a real weak point on these old Mopars.
