I haven't installed mine yet. Although not on this thread, there have been several other posts from members who have used this throttle body injection set up successfully. The main issue noted is with the "Fuel Command Center" add-on that is supposed to work with the OEM fuel pump. Based on what I've read, there were issues in the initial design with a check ball in a vent on the FCC causing fuel starvation issues, particularly on bumpy roads. Apparently they're have worked or are working on a correction.
I'm going to go with a in-tank fuel pump to there's no FCC in my future plans.
I
