blueprint 408 stroker
Author Topic: blueprint 408 stroker  (Read 4103 times)
Offline amethyst3500
« on: November 12, 2015 - 08:55:24 PM »
What does anyone think about this engine ?  Will this be a good engine for a 4 speed application? should I look for something with a roller cam and roller rockers? What rpm would this set up be good for ?
HP & Torque: 445 HP / 500 FT LBS
Compression Ratio: 10.0:1
Aluminum Heads
Hypereutectic Pistons
Flat Tappet Cam
Cast Steel Crank
Part #: BPC4083CTC
Block:
Seasoned 360 block
Square and parallel decked
Align honed main bearing bore
Cylinders honed on computer controlled machine to within .0002 straightness and roundness
Cylinders are sonic tested for thickness
Rotating Assembly:
New cast steel crankshaft
Hypereutectic pistons
I-beam rods
Hastings Moly rings
Balanced rotating assembly
High volume oil pump
Hydraulic flat tappet camshaft
Heavy duty double roller timing set
Cylinder Heads:
Aluminum cylinder heads
Hardened retainers and springs
2.02 swirl polished intake valves
1.60 swirl polished exhaust valves
Hardened push rods
Cam Specs:
Flat tappet
.545 Intake / .545 Exhaust
241 Intake / 247 Exhaust duration
@ .050 - 110 degree lobe separation
Ignition Timing:
34 degrees at 4000 RPM
Also Includes:
Aluminium intake manifold
Distributor
750cfm carb
Valve covers, oil pan and timing cover
Brass freeze plugs
Dyno tested – and shipped with results
Offline moper
Re: blueprint 408 stroker
« Reply #1 on: November 12, 2015 - 09:37:02 PM »
Google Blueprint engines. Personally - you can do better from a performance builder close to home. Much of that parts list is the cheapest parts available, and the labor, assembly, and warranty support are lackluster. The power levels are low for the build.
Overall it would be fine with a 4sp. But you could do much better in terms of parts and execution than Blueprint IMO.
Offline jimynick
« Reply #2 on: November 12, 2015 - 09:41:41 PM »
If you're going to run a HV oil pump, may I suggest an increased capacity oil pan? There's stories of sucking a stock pan dry at rpm and, as you're well aware, that dog won't hunt. Better minds than mine will no doubt chime in on your combo, but at first glance, it seems to be lots of cam for a street car. Not so bad for a stick, but maybe not an auto unless you go with a higher stall converter. Vacumn may be an issue if you're running power brakes, as well. Just my  :2cents:
« Reply #3 on: November 13, 2015 - 07:41:39 AM »
If I can purchase this new for less than 4k would it be a good deal ?
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #4 on: November 13, 2015 - 10:32:35 AM »
Potentially, yes.  However, in the long run you have a high chance of running into big time issues with a cheap build.  If there is one thing I have learned in this hobby, do it once and do it right.
Offline ChallengerHK
« Reply #5 on: November 13, 2015 - 10:37:09 AM »
On the most basic level, unless the seller were a good personal friend, I would never buy a complete motor without taking it apart and double-checking the build before installation.
- Han Solo, Star Wars
Offline moper
« Reply #6 on: November 14, 2015 - 09:34:58 PM »
If it can do what you want, and if it can do it for a length of time that gives you the return on investment - yes. I don't think it will in either respect. It's a cheap engine, built with cheap parts, and assembled by cheap labor.
As "they" say:
Fast
Cheap
Reliable
You can pick any two of the three.
Offline cameron2502
« Reply #7 on: November 15, 2015 - 11:37:15 AM »
I bought a 408 Blueprint through Summit 3 years ago and my advice is don't.
Offline mrjlr
« Reply #8 on: November 21, 2015 - 11:28:50 AM »
About a year ago, I put a Blueprint 383 stroker in my corvette. ....
Ran like a raped ape!  Sold the Stingray to buy my Cuda,  but I thought it was a great engine.
I'd consider rolling the dice with them again.
Offline mrjlr
« Reply #9 on: November 21, 2015 - 11:30:34 AM »
Why....what happened?
