Author Topic: Rear Sway bar on a Dana 60  (Read 4583 times)
« on: November 14, 2015 - 09:19:33 PM »
I still have my rear sway bar and hardware left from when I had a 8 3/4 rear end.
Has anyone here installed a factory rear sway bar onto a Dana 60 rear end?
Are there any interference issues or any reasons why nobody has one on a Dana 60?
I don't recall ever seeing an E body Dana 60 and have a rear sway bar added.
Offline KillerBee
Re: Rear Sway bar on a Dana 60
« Reply #1 on: November 14, 2015 - 09:33:12 PM »
I reused the factory sway bar on my 1971 R/T Challenger when I swapped it's 8 3/4 rear end to a Dana 60.
The Dana was from an original E-body so it was the correct width and the sway bar bolted right in with no issues.
Using a narrower B body width Dana would need some modifications to a factory sway bar.
Offline crash340
« Reply #2 on: November 14, 2015 - 09:42:32 PM »
I made offset swaybar connectors when I put a B Body housing into my E body using the factory E Body swaybar, works great no problems at all
Greg
73 Cuda
Brisbane, Australia
« Reply #3 on: November 14, 2015 - 09:49:25 PM »
thanks
On mounting to the frame, did you do anything different? Bolt thru the frame to other side?
Just wondering if the added weight/stress of the Dana creates a problem of the mounts coming off the frame.
Offline KillerBee
« Reply #4 on: November 14, 2015 - 09:59:52 PM »
thanks
No I removed the sway bar assembly, had it all sandblasted, painted everything then reinstalled with factory hardware including the frame bracket screws.
I was a little nervous as to what I was going to find when I removed the frame brackets but thankfully everything was rock solid.
It's been 2 summers of driving and everything still looks and works great.
The car is a 4 speed with a good running 440 Six Pack engine, I don't abuse the car but I do take the opportunity to open up all 3 carburetors every time I drive it.
Drilling completely through the frame rails to mount the brackets might not be a bad idea if you plan on really driving the car hard as those factory frame bracket screws look a little flimsy.
« Last Edit: November 14, 2015 - 10:04:23 PM by KillerBee »
Offline KillerBee
« Reply #5 on: November 14, 2015 - 10:02:16 PM »
That is pretty slick :2thumbs:
I'm thinking of installing a B body Dana under the wife's R/T Challenger.
I was just planning on bending the sway bar ends in. :dunno:
« Reply #6 on: November 14, 2015 - 10:13:06 PM »
Thanks KillerBee,
I don't plan on hanging this car thru turns hard either.
900+ lb Hemi up front limits my hard cornering.
« Reply #7 on: November 14, 2015 - 11:41:49 PM »
My factory bar worked with the Dana I upgraded to also with no issues , on one car I just bent the bar for the different width mounts & used std end links .
 drilling through the frame would be weaker IMO as the bolts can move inside the holes eventually elongating the holes , the sheet metal screws are tight in the mount holes at least
« Reply #8 on: November 14, 2015 - 11:44:41 PM »
 Drilling through the frame would be weaker IMO as the bolts can move inside the holes eventually elongating the holes , the sheet metal screws are tight in the mount holes at least
Good point. thanks
Offline crash340
« Reply #9 on: November 15, 2015 - 04:40:16 AM »
Killerbee, I simply used 5/8" bar (I think from memory), turned the ends to match the standard link ends and then simply bent a 1" offset.
They have been in there now for some time and no issues at all, self centering, all good
Greg
73 Cuda
Brisbane, Australia
« Reply #10 on: January 09, 2016 - 04:33:47 PM »
I talked to Roger, a respected opinion on muscle cars.
He felt that putting a rear sway bar on a Hemi car wold sacrifice off the line traction i.e: drag racing.
 :feedback:
« Reply #11 on: January 09, 2016 - 10:16:34 PM »
 :feedback:
I can't see that, but are you interested in drag racing? Like, would it be important to you if it sacrificed a tenth in the quarter?
« Reply #12 on: January 09, 2016 - 10:42:16 PM »
No of course not.
I told him I could always either disco the bar or loosen it.
I was just wondering how much does a rear sway bar affect tire plant on take off.
« Reply #13 on: January 10, 2016 - 12:30:25 AM »
the upgrade for 4 link systems for drag racing is adding an anti roll bar to plant the tires evenly , this would work the same on the rear with a dana
« Reply #14 on: January 10, 2016 - 01:13:47 AM »
On a scale of 1-10: Sway bar on, vs. no sway bar.
What difference is there in traction off the line?
