Author Topic: Rear Sway bar on a Dana 60  (Read 4584 times)
Offline TelisSE440
Re: Rear Sway bar on a Dana 60
« Reply #15 on: January 10, 2016 - 12:01:22 PM »
 :popcorn:
« Reply #16 on: January 10, 2016 - 01:08:22 PM »
Well it will definatly keep both tire more evenly planted , we have all seen pictures of Mopars standing on the right rear tire, so as a guess 4/10 improvement
Offline YellowThumper
  • I left the snow for this?
« Reply #17 on: January 13, 2016 - 12:56:16 AM »
Couple of points IMOP
I don't envision how a sway bar would limit traction. I do however see it possibly helping to plant both tires more evenly.  Also see it as a stability help at higher speeds.
As for them not coming with them from factory. I would expect when a Hemi was added straight line was the only consideration. Why add the weight and expense.
Also on the earlier mention of drilling out the mounting holes.
Drilling out the holes would allow addition of spacer sleeves the bolts would go thru. These would allow additional tightening without crushing the frame rail.
I myself would weld the sleeves in place.
« Reply #18 on: January 13, 2016 - 09:48:56 AM »
the front sway bar can limit front rise & weight transfer but the rear will not
« Reply #19 on: January 13, 2016 - 10:17:04 AM »
X2
