Author Topic: 8 3/4 rotating resistance feels like to much  (Read 1340 times)
Offline jdavis2169
« on: November 14, 2015 - 11:23:37 PM »
Hi guys. I had the rear end jacked up to change my lug studs. Trying to turn my sure grip w/ 3.23 gears it felt like there was a lot of resistance turning forward and would not turn backward. Brake drums were off so no brake resistance with car in neutral. Is this normal.
Re: 8 3/4 rotating resistance feels like to much
« Reply #1 on: November 14, 2015 - 11:27:44 PM »
As long as you are sure you were in neutral, I would have to say 'no'.
Offline jdavis2169
« Reply #2 on: November 14, 2015 - 11:48:33 PM »
I think I will try disconnecting the driveshaft tomorrow to see if it might be in the transmission or if it is the rear end.
Offline Sinatra
« Reply #3 on: November 15, 2015 - 12:03:44 AM »
That's definitely not normal.  Turning one wheel should turn the other in the same direction and rotate the pinion flange/driveshaft with very little effort.
Offline jdavis2169
« Reply #4 on: November 15, 2015 - 06:41:45 PM »
Ok took the driveshaft out I found resistance is in the transmission and the driveshaft is to long. I didn't even have enough room to get the u - joint out of the yoke with the rear end free hanging. Now to figure out what is up with the tranny.
Offline 1 Wild R/T
« Reply #5 on: November 15, 2015 - 07:03:09 PM »
What gear have you got?  More than a 3.55? Don't waste your time.... Depending on gear ratio it's pretty normal... Try the same test on another car with the same gear ratio...
Offline jdavis2169
« Reply #6 on: November 15, 2015 - 09:54:34 PM »
Ionly have 3.23 gears and a 440 4 barrel. It's enough resistance that it makes my car seem sluggish. I am replacing the tranny this winter anyways. I have a spare so all should be good by spring.
