Author Topic: Ignition column key switch for e body  (Read 685 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
« on: November 17, 2015 - 06:49:08 PM »
Hello all
Is the ignition switch the same for e body steering columns between column shift, floor shift, "depress to remove key" type,and 1970 columns? I received a new set when I bought a new project and was going to install it, but wanted to make sure before trying.
Thanks
« Last Edit: November 17, 2015 - 06:51:15 PM by Scat Pack Fever »
Offline anlauto
Re: Ignition column key switch for e body
« Reply #1 on: November 17, 2015 - 07:09:04 PM »
Yes
« Reply #2 on: November 17, 2015 - 08:05:48 PM »
Thanks!!!!!!!!
