Author Topic: 70 Cuda 383 starting issue  (Read 820 times)
Offline phunny
  • Newbie
« on: November 18, 2015 - 10:44:18 AM »
I have a 70 Cuda in the shop and the customer told me that when he shuts the car down a lot of the time he has to jump the solenoid for just a second and then he can start it with the key.  Not thinking starter as that would have nothing to do with what he does to fix it.  Anyone have any common issues.
While I'm on here the car likes to die at stops after it's fully warmed up...  Carb was rebuilt and it runs great otherwise.
Offline mopar jack
Re: 70 Cuda 383 starting issue
« Reply #1 on: November 18, 2015 - 10:54:56 AM »
On the dying at stops check if it has an idle solenoid. I've had the solenoids go bad and not hold intermittently causing the car to stall.
« Reply #2 on: November 18, 2015 - 08:42:05 PM »
could be a bad start relay  they are only $10 or so to replace
Offline 69ChargerRT
  • Its the car, right? Chicks love the car. - Batman
    • Daisy - My 1969 Dodge Charger R/T
« Reply #3 on: November 19, 2015 - 09:01:30 AM »
had that happen on my charger.  it was cheap to fix.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: November 19, 2015 - 03:21:35 PM »
I agree, work from the cheapest to the most expensive fix.
Most likely the starter relay.
