Author Topic: 110v mig welder with argon  (Read 3831 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
« on: November 19, 2015 - 05:49:20 PM »
Hello all
I am about to start on a new project, but don't have a 220v outlet at the moment. Does anyone use a 110v mig welder when plug, puddle welding body panels, trunk floors etc?
Thanks
Offline roadman5312
Re: 110v mig welder with argon
« Reply #1 on: November 19, 2015 - 05:52:22 PM »
  I have a Hobart Handler 140.  Great machine.    :2thumbs:               :rebel:
« Reply #2 on: November 19, 2015 - 05:54:19 PM »
I used a Lincoln 110 volt machine on my fender project, and subframe connectors...... and all the welding on my car.
Offline GoodysGotaCuda
« Reply #3 on: November 19, 2015 - 07:07:37 PM »
a 100-150a 110v machine will handle anything you want to weld on the car. The only hesitation would be axle brackets with something less than ~140a.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline NCCUDA
« Reply #4 on: November 19, 2015 - 07:11:16 PM »
Eastwood 135- I have welded almost everything with it.  Great adjustments for panel work.
« Reply #5 on: November 19, 2015 - 07:21:52 PM »
If you are an impulse buyer, Zoro tools has 25% off orders over $250, ending TONIGHT [ends at midnight]
Code: YOURGIFT25
1976 Dodge Warlock
« Reply #6 on: November 19, 2015 - 07:54:26 PM »
Thanks for responses! Is a common household outlet 110v, 115v, or 120v?
Offline 734406pk
  • Andy
« Reply #7 on: November 19, 2015 - 08:01:55 PM »
Yes it's 110-125 volts. You will need at least 15 amp circuit. 20 amps would be better.
Offline AARTA340
« Reply #8 on: November 19, 2015 - 08:40:55 PM »
 :iagree: And a dedicated circuit as well would be beneficial. I have a Lincoln 135 and has done very good on the car sheet metal, and agree on heavier stuff like spring perches and similar you could use the smaller ones, but with a couple overlapping passes. If you have more than a few heavier items to weld a welder with 140 amps or more would be better. Again, for a few heavy welds the smaller ones should be more than ample and the additional cost for a larger welder may not be a necessity.  :2thumbs:
Offline Cudakiller70
« Reply #9 on: November 19, 2015 - 09:36:30 PM »
Also extension cord heavy gauge and short as possible. For welding sheet metal I use .023 wire, .035 wire would be for me doing frame welding with that machine. That's just me.
The above is just my opinion
John Adams
« Reply #10 on: November 19, 2015 - 10:57:54 PM »
Hello all
Where you live, do you have an electric dryer?
That's what I used to run 220v.
Offline BS CUDA
« Reply #11 on: November 19, 2015 - 11:14:05 PM »
Yup quite certain that would solidify the divorce. Oven used to bake paint, dishwasher as a parts washer, cupboard as a supply cabinet,  etc............. And now she's hanging clothes in the basement.
Offline dougs bs23
« Reply #12 on: November 20, 2015 - 01:11:16 PM »
Quote from: BS CUDA link=topic=109493.msg1078108#msg1078108 ........... And now she's hanging clothes in the basement.
[/quote
But honey. I'll build you an outside clothes line. The towels and sheets will have that lovely outside smell of fresh air.
« Reply #13 on: November 20, 2015 - 01:58:40 PM »
Gas, gas, gas, I think you should be using a 75/25 mix Argo/co2. This is what most of our welder so used for thin metal. My  :2cents:
Here is a welding link
http://weldingweb.com/showthread.php?50780-MIG-100-CO2-or-75-25-Argon-CO2
John Adams
Offline 734406pk
  • Andy
« Reply #14 on: December 08, 2015 - 08:32:04 PM »
Yes use "C-25" gas for MIG welding body panels. You Should get better flow and wet-out of the weld puddle resulting in very little clean up grinding. A major time saver!
