295 tire applications 71 Challenger
Author Topic: 295 tire applications 71 Challenger  (Read 3147 times)
Offline 440 SixPack
« on: November 20, 2015 - 07:53:52 AM »
Hello guys!
I drive a 71 challenger R/T and want some 295 BFG- tires on back! I know with the magnum wheels and 4 1/2 backspace it isn´t enouth place for the rubber and so I am interrested at the "offset hanger/shackle kit"!
Does anyone have 295 tires on the back with this kit or without???
THANKS!  :feedback:
Tim
Offline crash340
Re: 295 tire applications 71 Challenger
« Reply #1 on: November 20, 2015 - 08:26:00 AM »
I have 295's on 10" rims with 51/2" bs, 1" offset Spring hangers on a B body diff housing in my Cuda and they just barely fit
Greg
73 Cuda
Brisbane, Australia
« Reply #2 on: November 20, 2015 - 10:03:57 AM »
I ran 295/50s on 15x8 rims with 4.75 back space on the stock location suspension with no interference. It was very close to the rear leaf segment, but it didn't rub.
I am now running a 305/45 on 15x10 with 5" backspace, springs moved in 1" per side, and a '67 B body housing. I have plenty of room all around.
If you only offset the leafs 1", you could run a 5 to 5.5" backspace rim.
« Reply #3 on: November 20, 2015 - 03:49:23 PM »
I got a 295/50 nitto  in on an 8 " rim with careful diff centering
Offline 69CHARGERMD
« Reply #4 on: November 20, 2015 - 05:29:28 PM »
295/65/15 Drag Radial
Dr Diff's offset shackles, stock wheel wells,,with a B body DANA ( which is just a bit more narrow than a E Body Dana )
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline 69CHARGERMD
« Reply #5 on: November 20, 2015 - 05:31:41 PM »
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline JoeGrapes
« Reply #6 on: November 22, 2015 - 11:03:05 AM »
I have 295/45-18 with 5.75 BS. I moved the springs 3/4" but I didn't need to. The tires were close, about 1/8" but I have plenty of room at the wheel lip so if I went with 5.5 BS that would have been perfect. When I upgrade the suspension this spring I'm taking out the relocation brackets and if I really need to I'll just put a thin spacer between the wheel and hub.
Offline Mpdlawdog
« Reply #7 on: November 22, 2015 - 11:04:38 AM »
How wide of a rim are you running??
Offline JoeGrapes
« Reply #8 on: November 22, 2015 - 11:55:28 AM »
 Billet Specialties Split Spoke 17 x 8 in the front and 18 x 9.5 in the rear.
Offline Plum Crazy 71
« Reply #9 on: December 01, 2015 - 10:46:47 PM »
How wide is the rear rim?  10"?
Offline JAS
« Reply #10 on: December 14, 2015 - 10:30:36 AM »
A 295/50r15 4.5bs 15x10 will only fit with air shocks, the leaf will be close depending on tire choice.  I ran a much bigger tire on a 15x10 4" bs and wasn't even close to the leaf... now the fender lip is a different story.
