Author Topic: Hydroboost and proportion valve question  (Read 6112 times)
Offline mopar jack
Re: Hydroboost and proportion valve question
« Reply #15 on: November 24, 2015 - 12:34:48 PM »
I have a service manual break away view if I can post it correctly.
Offline Cudakiller70
« Reply #16 on: November 24, 2015 - 01:03:03 PM »
That's awesome, where did you get that? Is it a manual online in pdf or?
The above is just my opinion
John Adams
Offline shawge
  • Zoiks!!
« Reply #17 on: November 24, 2015 - 01:27:04 PM »
MyMopar has the manuals online
http://www.mymopar.com/index.php?pid=109
- Jerry
« Reply #18 on: November 24, 2015 - 01:35:46 PM »
People here are Great! This will be a big help for lots of stuff. Thanks, sometimes I just can't find anything.  :o
John Adams
Offline mopar jack
« Reply #19 on: November 24, 2015 - 02:08:57 PM »
that's from a factory service manual that was given to me back in the mid 70's. I agree that my mopar.com is a great resource for service and parts manuals.
Offline 74BlueFish
« Reply #20 on: November 26, 2015 - 08:42:20 AM »
OK,   I installed the new mater cylinder after bench bleeding the the proportion valve with the spring and green tube left out.
Couldn't bleed the rear, no fluid came out,  moved to the front and they bled fine.   Turned attention the the rear again and disconnect line at distribution block at rear axle, no fluid.  WTF     Checked pressure at exit of prop valve and have pressure.
Go figure, my new adjustable prop valve won't pass any fluid with the knob all way in or out!!!
When I get the new one I'll let everyone know the final results.
Dan
Offline mopar jack
« Reply #21 on: November 26, 2015 - 03:15:33 PM »
what valve do you have? I have a Summit valve and all the way out shuts off pressure to rear.
Offline 74BlueFish
« Reply #22 on: November 26, 2015 - 03:33:06 PM »
Mine works the same.     Baer.   Is the maker
Dan
